Thread started 21 Aug 2022 (Sunday) 18:28
R6 Viewfinder Question
tmwhitm
Aug 21, 2022 18:28 |  #1
Wondering if it is me seeing things. I have my new R6 and while out testing, I look through the viewfinder and the top corners look warped, as if a page from a book bent back. Just curious if anyone else is seeing that? Photos appear fine In Editing software.
Thanks,
Tom
Canon 30D | Canon 7D | Canon R6 |Sony α6000 / ILCE-6000 | Sony E 3.5-5.6/PZ 16-50 OSS | Sigma DC 17-70mm | Canon EF 70-200mm f/2.8L USM | Canon EF 70-200mm f/2.8L IS II USM |Canon EF24-105mm f/4L IS USM | Canon RF 50mm f/1.8 STM
bpalermini
Gallery: 203 photos
Joined Mar 2011
Aug 21, 2022 18:55 |  #2
Mine does not look like that. All four corners are sharp and normal.
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
tmwhitm
Aug 21, 2022 19:11 as a reply to  @ bpalermini's post |  #3
Errrr, thanks. I guess a trip back to the Photo shop tomorrow will be in order. Thank you.
Wilt
Post edited over 1 year ago by Wilt.
Aug 21, 2022 21:58 |  #4
tmwhitm wrote in post #19418059 (external link)
The EVF shows you what the sensor is seeing. If you have a comparatively low priced lens that has not-great control of distortion, you can be seeing that lens' shortcomings on your R6, even while someone else (with a different brand/model lens on their R6) sees no issues via the EVF.
How does the EF 70-200mm lens look mounted on the R6 (with suitable mount adapter)? Its image should be pretty free of any distortion.
tmwhitm
Aug 22, 2022 06:40 as a reply to  @ Wilt's post |  #5
Interesting, I had the new RF 50mm 1.8 mounted. I didn’t try the 70-200. I will have to give that a try and see. I was planning a trip to the Photo Shop at lunch where I purchased the camera. Interesting to think the 50mm has some distortion. After all these years with the OVF, this is all new. Thank you,,,
Wilt
Aug 22, 2022 11:52 as a reply to  @ tmwhitm's post |  #6
Here is a test report
https://www.photozone.​de …_eos_ff/1108-canonrf50f18 (external link)
It says the RF 50mm has a negligible amount of distortion, although the "There is always a lens that is the bottom feeder in the lineup and within the range of prime lenses, this is usually a nifty-fifty. In R-mount we are talking about the Canon RF 50mm f/1.8 STM which is, by far, the most affordable prime lens offered by Canon at least."
tmwhitm
Aug 22, 2022 12:36 as a reply to  @ Wilt's post |  #7
Hi Wilt, Thanks. I tried tested with my 70-200 and I am seeing the same. I actually just got back from the shop. Two guys looked at it and said they couldn’t see what I was seeing. They suggested I shoot some test images with lines and see if the sensor itself is fine. I will have to do this quick as the grace period for return/exchange is 2-days away since I purchased the camera. We looked through another R6 with my 50mm & their 50mm 1.2L, very nice lens BTW, on my camera the effect was the same and on the other R6 I was still seeing it but not to the degree on my camera. It may just be my perception right now because I am getting anxious regarding the returns and that everything is as it should be on the camera. I have to be careful because everything I see now I don’t want to perceive as an issue and feeling comfortable with the camera.
tmwhitm
Aug 22, 2022 13:32 as a reply to  @ bpalermini's post |  #8
When testing, look through the viewfinder and hit the Q button so you can see the camera options running vertically up and down both sides. That is where I notice the ‘distortion’ in the top left corner …
Wilt
Post edited over 1 year ago by Wilt. (6 edits in all)
Aug 22, 2022 18:26 |  #9
Just draw yourself a 'grid' using pencil and using a ruler to make lines parallel to each other, and do so horizontally and vertically. (Or use a graphic drawing program to make a grid that you print.) Then tape that drawing to a wall, and (hopefully) you set your camera on a tripod aimed perfectly parallel to the wall and line drawing. Set your camera distance so you have a set of lines as close to the four edges of the frame as you can (and they are still within the viewfinder limits), then shoot some shots and print them to see how parallel to the edges of the paper the lines have been captured by your sensor (and compare to what you see in the EVF).
tmwhitm
Aug 22, 2022 20:16 as a reply to  @ Wilt's post |  #10
Thanks Wilt, I have wall paper that has vertical lines, Don't ask, LOL, and took some shots and I do not see any distortion. I am going to just have to keep shooting and see if anything pops up. I do have the Canon CarePak so that's a plus. I appreciate everyone's help. Tom
Wilt
Aug 22, 2022 20:20 as a reply to  @ tmwhitm's post |  #11
So if you see no lines in a photo taken of you wallpaper, do you seem to see distortion in the EVF (which is not in the photo viewed on computer monitor)?
tmwhitm
Aug 22, 2022 20:52 as a reply to  @ Wilt's post |  #12
Correct, what I think I am seeing is a distortion in the display through the EVF. I had asked the photo shop if what I see was right off the sensor and I was told no. The sensor sends the information to the EVF which is separate hardware from the sensor. So if what everyone else isn’t seeing is an issue, it would be in the EVF hardware.
Wilt
Post edited over 1 year ago by Wilt. (3 edits in all)
Aug 22, 2022 23:08 |  #13
tmwhitm wrote in post #19418442 (external link)
The sensor pixels ('sensels') are Red or Blue or Green sensitive only...it is conversion of the signals (changing eacg pixel to a single R-G-B value based upon the signals of its neighbors, via postprocessing of the sensor signals to create a JPG preview image which is sent to the EVF 60 or 120 times per second (depending upon camera design)...so you are never 'seeing the sensor' literally (you are not seeing 'RAW' data), but an interpretation by the JPG processor of what is hitting the sensor.
'Distortion' in the EVF might be a simple optical distortion caused by the optically simplistic eyepiece, and not at all a distortion of data displayed on the LED.
IF you see distorion in your EVF but another R6 belonging to someone else looks absolutely fine to YOUR eye, then something is not right with your camera.
tmwhitm
Aug 25, 2022 13:40 as a reply to  @ Wilt's post |  #14
Hi Wilt, just an update. I visited the store twice. Long of the short, I ended up exchanging the camera. The new camera EVF looks better as I would expect it to. I also noticed something else. The first camera was the last one on the shelf when I picked it up. This exchanged camera 'feels' different, i.e. more brand new and as I go through all the settings, it's almost as if they were different initially on the first one. I have found that the Camera Reset option does NOT reset the camera to factory defaults. I have had to go back in to remove custom options & Copyright information, so maybe it wasn't so new. This one, They actually brought this one from the back so, who knows. Going to be testing some sports shooting tonight. I appreciate all your help. Tom
1,101 views & 1 like for this thread, 3 members have posted to it and it is followed by 3 members.
1456 guests, 130 members online
