Posting here since I can’t find a specific forum for it. I have the Tamron 150-600 G2 for the EF mount, an use it on an EOS RP with a mount adapter. Is there an extender that will work with this combo?
Dec 15, 2022 21:03 | #1 Posting here since I can’t find a specific forum for it. I have the Tamron 150-600 G2 for the EF mount, an use it on an EOS RP with a mount adapter. Is there an extender that will work with this combo?
wimg Cream of the Crop 6,982 posts Likes: 209 Joined Jan 2007 Location: Netherlands, EU More info | Dec 16, 2022 06:08 | #2 DannyC71 wrote in post #19456819 Posting here since I can’t find a specific forum for it. I have the Tamron 150-600 G2 for the EF mount, an use it on an EOS RP with a mount adapter. Is there an extender that will work with this combo? Any EF-mount extender between lens and RF-adapter will work with it. EOS R & EOS 5 (analog) with a gaggle of primes & 3 zooms, OM-D E-M1 Mk II & Pen-F with 10 primes, 6 zooms, 3 Metabones adapters/speedboosters, and an accessory plague
wimg Cream of the Crop 6,982 posts Likes: 209 Joined Jan 2007 Location: Netherlands, EU More info | Dec 18, 2022 07:30 | #4 DannyC71 wrote in post #19457382 Thanks It's only a pleasure! EOS R & EOS 5 (analog) with a gaggle of primes & 3 zooms, OM-D E-M1 Mk II & Pen-F with 10 primes, 6 zooms, 3 Metabones adapters/speedboosters, and an accessory plague
AntonLargiader Goldmember More info | Dec 18, 2022 09:08 | #5 Would an RF extender between the adapter and the body work just as well? If the OP needs to buy something new, might as well go more future-proof. Image editing and C&C always OK
wimg Cream of the Crop 6,982 posts Likes: 209 Joined Jan 2007 Location: Netherlands, EU More info | Dec 19, 2022 10:25 | #6 AntonLargiader wrote in post #19457465 Would an RF extender between the adapter and the body work just as well? If the OP needs to buy something new, might as well go more future-proof. Yes, it should, and will. EOS R & EOS 5 (analog) with a gaggle of primes & 3 zooms, OM-D E-M1 Mk II & Pen-F with 10 primes, 6 zooms, 3 Metabones adapters/speedboosters, and an accessory plague
joeseph "smells like turd" More info | Dec 19, 2022 18:12 | #7 I have seen a discussion that talked about the Canon RF extender having a front tube that was too large to fit a RF-EF adapter, needing a bit of "modification" of the adapter to get it to fit. Will post a link when I find it again... some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited 10 months ago by Wilt. | Dec 19, 2022 18:17 | #8 joeseph wrote in post #19458078 I have seen a discussion that talked about the Canon RF extender having a front tube that was too large to fit a RF-EF adapter, needing a bit of "modification" of the adapter to get it to fit. Will post a link when I find it again... Let me be of service... "Hacked: Making All Canon EF and EF-S Lenses Compatible with Canon RF Extenders An aftermarket brand item, both telextender and RF-to-EF adapter, might be compatible with each other. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
wimg Cream of the Crop 6,982 posts Likes: 209 Joined Jan 2007 Location: Netherlands, EU More info | Dec 20, 2022 06:32 | #9 Wilt wrote in post #19458081 Let me be of service... https://www.the-digital-picture.com …20Canon%20mount%20adapter "Hacked: Making All Canon EF and EF-S Lenses Compatible with Canon RF Extenders An aftermarket brand item, both telextender and RF-to-EF adapter, might be compatible with each other. Thank you, Wilt, for that information! EOS R & EOS 5 (analog) with a gaggle of primes & 3 zooms, OM-D E-M1 Mk II & Pen-F with 10 primes, 6 zooms, 3 Metabones adapters/speedboosters, and an accessory plague
AntonLargiader Goldmember More info | Dec 20, 2022 06:48 | #10 Canon's adapter has a similar baffle but it's shaped a bit differently. Were it my project, I would put it in a lathe and make the ID large enough to accept the extender. This is exactly the sort of thing a lathe is for. Image editing and C&C always OK
joeseph "smells like turd" More info | Dec 21, 2022 01:44 | #12 thanks Wilt! exactly the page I was mentioning. some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
| Latest registered member is semonsters 1301 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
