Large ELINCHROM Lot. Asking $4500 (will consider swap for 3-4 Broncolor Siros of similar condition)
6 Flash Units, 7 Reflectors, 3 Softboxes, 1 octa-box, Transmitters, Bags etc.
It's a lot of stuff so best for local Picup, but if you want to pay ship and insurance we can talk.
Includes:
2x 1000 joules/watt seconds Monolight Flash Heads with cables
4x 500 joules/watt seconds Monolight Flash Heads with cables
3 Padded Elinchrom Bags each for 2 Flash Heads
6x Elinchrom EL26170 Wide reflectors (90° light spread)
1x Elinchrom Skyport Speed transmitter (for all cameras)
1x Elinchrom EL-Skyport transmitter Pro for Sony
1x Long Camera Sync-cable
1x EL26071 High Performance Reflector 26cm /10.2" (48° light spread)
1x Rotalux EL 26646 Octabox 100cm/39" with EL26570 Speedring, Bag and 1x Inner and 1x outer Diffusion panel.
3x Elinchrom Portalite Square Soft boxes with Bag 3x Portalite Speedrings and 1x Square Diffusion panel)
1x EL26310 Deflector kit (Not Pictured)
1 Set of user manuals
About these Units:
All units have low use. two sets (1000ws and 500ws) are in Excellent like new condition.
One 500ws set has a little more use than the others. This set also has an issue with the skyport in one of the two heads. All units have working Flash tubes and modelling lights.
Specs one these are:
1000 ws heads: Each heads hase been powered on less than 25 times and have less than 13 hours use.
One has had less than 2700 total flashes, the other less than 2100.
500ws heads:
Set 1: One head has been powered on less than 60 times has less than 24 hours and less than 3300 total flashes,
The other head has been powered less than 90 times has less than 50 hours and under 6000 total flashes
Set 2: which has one head with a working sky port and one where the sky port doesn't seem function, but works with a sync cable, or receiver (any brand) attached to sync port and in flash slave mode. Each of these units has been powered on fewer than 150 times and have less than 65 hours. One unit has less than 6000 total flashes the other less than 8000.
