Thread started 16 Aug 2003 (Saturday) 08:10
G3 close-up & macro - and nomel's trick
flowe
Joined Mar 2003
Aug 16, 2003 08:10 |  #1
I tried to sort out G3 close-up and macro and to fit "nomel's trick" into the picture:
Have a look @: http://homepage.hispee​d.ch …/digifoto/g3-close-up.htm (external link)
savage ­ om
Joined Aug 2003
Aug 16, 2003 08:48 |  #2
Ok- question: If someone wanted to create something that was actually designed to do this, then it would involve designing modification of the barrel, and not the camera itself right?
As in- someone could potentially design and package (for sale) a 'G3 compatible modification of standard lense assembly' that was designed to do this?
BTW- 'designed to do this' means the new design addresses all the bugs involved in doing it the jury rig method.
- the Canon 'Nomel Adapter' part LA-XXXXXXX -
nomel
Joined Aug 2003
Aug 18, 2003 23:38 |  #3
Just to let you know,
I have been able to use the manual focus for distances greater than 2 feet (according to the position indicator), but anything less than 2 feet causes bad sounds. And, if your subject is in the range that actually focus's, autofocus seems to work fine. I don't reccomend this even slightly, but, just to let you know. :) I do use it that way often (for stress testing).
sprockett
Joined Jan 2003
Aug 21, 2003 13:36 |  #4
can i use this focussing ring method:
a) NOT using full zoom
b) for random subjects at different distances rather than macros?
nomel
Joined Aug 2003
Sep 12, 2003 14:14 |  #5
Yes, it can be used for non macro shots. I use it as a manual focus anytime instead of the awfull wheel.
And for a modification. I'm sure it could be done in firmware (which I doubt can be modified). It could be done electronically, so that the motor turns the ring instead of you, which would get rid of any bad forces on the gears. But, I doubt it could be done without getting to the motor (which I have thought about).
4,553 views & 0 likes for this thread, 4 members have posted to it.
1825 guests, 137 members online
