BLANKphotog wrote:
what f stop do i shoot on?
thanks for the tips and comments
According to the EXIF data from your image, you shot with flash at 1/40" and f/13 in manual mode. I do not see the camera type in the data.
There is no correct answer to the question of what f stop to use. It is very dependent upon many factors and which factor is most important to you. However, in this case, based upon what I see in the picture, I believe that the ambient lighting dominated and the flash only provided some fill in of shadows.
I believe that in a similar situation I would have opened up and shot at a larger aperture, say f/5.6 or f/8, in order to be able to use a faster shutter speed. This is because if you are shooting hand-held, the 1/40" is not fast enough. The depth of field would still be more than adequate, if you are properly focused.
