Thanks for all the info. I wasn't aware that you could remove the card and the Custom WB would still work. I guess that's what I get for "assuming" that it would be a problem. So, I don't need to worry about it. As for the Custom WB not being equating to a temperature, that seems odd... but I'll take your word for it. From working with WB, it seems that its always a temperature. If you shoot in RAW, when you look at the image while it still has it's RAW capabilities, it seems that the Custom WB is represented as a temperature, and in fact you can also tweak it up or down. I still would like to be able to equate the Custom WB to a number, though... because when I have multiple bodies that I'm shooting with in one venue, and I want to have the WB match, it would be much easier using a number.
As for shooting RAW being a solution, its not for me. I do not want to have MORE processing to do when I get back to the office... I want less. I want to get the WB correct at image capture time and not have to fiddle with it in capture RAW. My workflow is JPEG for most shoots, and I only use RAW when I'm shooting a small number of images and need the maximum amount of editability. It may just be my lack of skills, but I'm a JPEG shooter 97% of the time.
