Thread started 02 Apr 2006 (Sunday) 15:48
Couple of American Goldfinches
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Apr 02, 2006 15:48 |  #1
Giving the 500mm some more workout today, along with the 1.4 TC and the Better Beamer since the sun was stuck behind some trees.
IMAGE: http://www.itsanadventure.com/postimages/Goldfinch_64364.jpg
IMAGE: http://www.itsanadventure.com/postimages/Goldfinch_64399.jpg
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Apr 02, 2006 15:52 |  #2
Great colors and great bokeh.
What is a "Better beamer"?
EDITING OF MY PHOTOS IS NOT ALLOWED
Scottes
Joined Nov 2003
Apr 02, 2006 15:57 |  #3
The BB is an attachment to go on a flash. It uses a Fresnel lens to focus the flash to a tighter beam, giving much more distance when using long lenses.
http://www.luminous-landscape.com/reviews/​better_beamer.shtml (external link)
It's a very cool attachment for long-distance photos, but I'm really not a lover of the flatness of flash shots so I'd usually try to add a tiny hint of light with it. The trees blocked most of my nice sun, though, so the flash was predominant. I need to convince my neighbor to take down about 6 100-foot pines and a couple of 60-foot maples...
Blue ­ Deuce
"I don't say anything witty"
Apr 02, 2006 15:57 |  #4
I take it you shot #2 wide open with such a shallow dof. These are good. Doesn't look like there was any loss with the 1.4x.
Any feedback on the beamer and what settings are you dialing into your flash ? I have not found too many resources on it. Guess I will just have to practice, practice, practice.
dancinec
Apr 02, 2006 16:10 |  #5
Wonderful Goldfinch shots Scottes, I have tried the better beamer, but I find that it scares the birds too much. I usually put the camera in Tv mode and let it decide on the shutter speed. Is there a better way to do it? The instructions suggest an off-camera bracket for the flash, but it is heavy enough with adding the weight of a bracket.
Dennis
Canon 20D, 30D, 40D, 50D, Canon 100 mm Macro, Canon 100-400mm, Canon 400mm 5.6L, Canon TC 1.4X, Tamron 28-75 mm, Bogen 3221 Tripod, Kirk BH-1 ballhead, Sigma EF-500 DG Super Flash, Canon 580 II Flash, Better Beamers, Whimberly Plamp.
My galleries (external link)
reewik
Joined Dec 2004
Apr 02, 2006 16:13 |  #6
Very well done for someone new to the lens...
Eric: www.avianart.net (external link)
Canon 1D MKIII, 600 f4 IS, 85 1.2L
Canon 1D (Classic),50 2.5 Macro, 1x lifesize
stoneylonesome
Barn Stormer
Joined Aug 2003
Apr 02, 2006 16:34 as a reply to  @ reewik's post |  #7
Holy Cow! those are beautiful. The colors and detail really jump out at you.
the name is Winston but they call me Sandy
"Everybody's got to believe in something. I believe I'll have another beer." --W. C. Fields
Flowing River Photos (external link)
Scottes
Joined Nov 2003
Apr 02, 2006 16:47 |  #8
Thanks for the comments everyone!
As to tips for the BB, I really have no idea as this is the first time I've used it. I think the best thing to do is "practice, practice, practice" along with "experiment, experiment, experiment." Although if Liquidstone ever reads this he may have some ideas...
So far flash is really fairly confusing to me. This make using the BB tough when combined with the fact that I don't like that "flat" effect that flash generally has. But I've seen some stuff to convince me that it is certainly useful at time, so I'm going to bang away at it and see what that yields.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 02, 2006 17:28 |  #9
They look great Scott!
The key with the beamer used for fill is to keep things toned down.
I usually continue to work in AV mode as I would with no flash,. and have -2/3 or -1 full stop of FEC dialed in with the beemer for starters,. I use the FEC built into the camera most often as I can tweek it faster,. but I've been told a few times that the results are better to dial in your FEC into the flash unit.. ? Don't know why this would make a difference really.
The less you rely on the flash the more you preserve natural lighting. Of course when all is in shadow you have little choice in the matter. Ive seen lot of shots in nature magazines where the conditions are after nightfall,. or the shots are taken under the dense cover of a rainforest (essentially it's perpetually night down there) where you have no choice but to use the flash as a main light,. and done well this can still look quite good.
Scott,. in these shots with the dark background near black,. (more so in the second) this looks to be the case,. the flash has by necesesity become the main light near as I can tell.
What exposure mode and exif resulted?
CDS' HOT LINKS
Gary ­ Fairhead
Apr 02, 2006 17:40 |  #10
Beautiful shots with great backgrounds. I have to get a BB as I am hearing about and seeing a lot of positive results. Nice!
Scottes
Joined Nov 2003
Apr 02, 2006 20:27 as a reply to  @ CyberDyneSystems's post |  #11
A/Vmode - f/6.3, 1/250th, ISO 400 for the first and f/5.6, 1/250th, ISO 200 for the second. I believe that I had FEC -2/3 so I guess I should have gone lower.
The background now is a problem since the trees in the back yard are leafless and dark, and the grass is more brown than anything. In the summer the leaves will reflect more light, as will the green grass. This will make for much brighter backgrounds.
I will probably move the feeder over so that my neighbor's house will be in the background. It's a bright cream-white house that catches a lot of sunlight, so the bg will be much brighter and the flash will become fill-flash rather than primary lighting like it is here.
What I really like is that I can stay inside the porch will a lens this long, so I have a huge, huge blind...I also have a second 550EX now (my wife's) so I can set up a master-slave and place the primary outside at an angle to the bird. That should reduce the "flatness" since the primary flash will hit the birds at a 30- to 45-degree angle to the bird.
cfcRebel
Apr 02, 2006 21:27 |  #12
Those are excellent captures. Razor sharp and vivid colors.
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
Raj
Joined Dec 2004
Apr 02, 2006 21:30 |  #13
WOW, so sharp, detailed, well exposed & saturated.
These are just WOW images !
1DX, 5D, 20D with BG E2, Sigma EX DG 8mm F3.5 Circular Fish Eye, EF 15 mm f2.8 fish eye, EFS 10-22 mm f3.5-4.5, EF 24-70 F2.8 L mark ii, EF 24-105 f4 L IS, EF 16-35 f2.8 L , Sigma 35mm f1.4 A, 50 f1.8 mkII, 50 mm F1.2 L, EF f85mm 1.8, EF 100 f2.8 macro, EF 135 F2 L, Sigma 70-200 f2.8 EX HSM, EF 70-200 f2.8 L, IS USM mark ii, EF 100-400 f4.5-5.6 L IS, Sigma 18-125 f3.5-5.6 DC, APO 1.4x, G3, Cheapy Velbon Sherpa 435, Slick Carbon Fiber, Speedlite 430EX and 580EX with stofen OM-EW
Airedale1
Gallery: 80 photos
Joined Jan 2005
Apr 03, 2006 00:15 |  #14
Beautiful captures. I really love the second one.
Sony RX10 M4
Canon S90
SamAlfano
Apr 03, 2006 08:14 |  #15
Those are really crisp shots. I prefer number 2, but they're both excellent. You're really getting the hang of that lens!
3,777 views & 0 likes for this thread, 22 members have posted to it.
1682 guests, 138 members online
