Thread started 18 Aug 2003 (Monday) 23:27
Splotchy appearance
diggy
Joined Jun 2003
Aug 18, 2003 23:27 |  #1
I have a Canon PS 50 which I love; however, when printing pics on my Epson Stylus Photo 820 printer, the pictures seem to have a "splotchy" appearance.
The appearance is mainly on sky, clouds, complexion, and walls. This happens no matter if I use normal, fine, or superfine compression. I have resolution set on small (640 x 480 pixels). I've also increased the resolution and it still happens.
I use 10 mil Hammermil Professional Photo Paper, brilliant gloss finish or Royal Brites Ink Jet High Gloss Photo Papoer.
The Royal Brites photo paper is from Sam's Club -- 150 sheets for $30. Pics actually print better on it than the Hammermil brand.
Any suggestions please?
stopbath
Joined Jul 2003
Aug 21, 2003 14:09 |  #2
Does the splotchy appearance happen more on the Hammerhill paper?
What about normal printer paper, is the less quality paper still blotchy?
Have you used ink other than original Epson? (refilled) That might be your problem. Did you try Epson paper? Check your printer settings, something may have been set to a setting that doe not work.
Is the blotchy in rectangles? This might be from extreme jpeg compression. Try unedited photos. If the blotchiness if from editing, save at higher quality.
John_T
Gallery: 127 photos
Joined Jun 2003
Aug 21, 2003 15:01 |  #3
Sounds like the splotches appear on larger same colored surfaces. Sounds like the paper isn't taking the ink properly. If you are using Epson original inks, try Epson paper and see if the same thing happens. If you are using off brand inks or refills, you don't have to look further.
Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
diggy
Joined Jun 2003
Aug 21, 2003 15:07 |  #4
I'll check this out and let you know back. Thanks for your response.
diggy
Joined Jun 2003
Aug 21, 2003 15:09 |  #5
I'm using new Epson ink cartridges (never refilled ones).
However, I haven't tried "Epson paper" -- I'll try that when I can get to the store and get some.
Will let you know how it goes. Thanks so much for your response.
John_T
Gallery: 127 photos
Joined Jun 2003
Aug 21, 2003 15:14 |  #6
Actually I tried to use some HP paper with my Canon printer and got the same thing, so that's why I think it's an ink/paper thing.
1,966 views & 0 likes for this thread, 3 members have posted to it.
Splotchy appearance
1740 guests, 134 members online
