Thread started 04 Apr 2006 (Tuesday) 19:21
What needs fixin?
CanonCam
Apr 04, 2006 19:21 |  #1
I am trying to get some practice shooting motion in before baseball starts here so I took a few of these geese. What can I change here? Thanks for looking!
Canon 20D, 24-70mmL, 17-85mm IS, 70-300mm IS, 50mm 1.8, 580EX
jbkalla
Joined Feb 2006
Apr 04, 2006 19:50 |  #2
Nice! Look like the one is still running!
John
flickr (external link) | G+ (external link) | Panoramio (external link) | InterfaceLIFT (external link)
Fujifilm X-T2
| 10-24 f4 R OIS | 50-140mm f/2.8 R LM OIS WR | XF100-400mm f/4.5-5.6 R LM OIS WR | 16-55mm f/2.8 R LM WR | 56mm f/1.2 R | 27mm f/2.8 Pancake |  Retina iMac & MBP
Robert_Lay
Apr 04, 2006 23:47 |  #3
Very nice picture, but you are attempting to get away with murder.
1/125" with a 210 mm lens at ISO 400 is overly optimistic. You need a lot more light and a much faster shutter speed to get away with this action stuff. Plan on using your highest ISO setting and your widest aperture and being as careful as possible with focusing. You are also at least one half f-stop underexposed on this shot.
Keep in mind that with your 1.6 lens factor, that 210 mm lens should never see a shutter speed any slower than 1/250" hand held, so you really need some artificial stabilization, such as a monopod or tripod.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
ibdb
TD's worst nightmare!
Location: Puyallup -- Don't worry. Nobody else can pronounce it either.
Apr 05, 2006 00:54 |  #4
Sorry -- for some bizarre board reason, I don't see your attachment. If I try to show the picture, I still don't see anything but a red x. If I quote you, I get a link to the attachment that I can select to see your image.
thumbnail
Hosted photo: posted by CanonCam in
./showthread.php?p=136​5619&i=i41404476
forum: Critique Corner
About the image: Robert_Lay says it better than I could. Motion requires a lot of light. This is a little too dark for me (underexposed). You might not need to max out your ISO, but it wouldn't hurt. If your goal is freezing the action, then definitely crank it up. If you're trying to freeze part of the action (say the batter) but not everything (not the bat), you might want to go a little lower. Same thing with trying to freeze a pitcher vs. getting a blurred hand/arm. If motion is the goal, then artificial stabilization (even IS) will be necessary.
I do like the sense of motion in this shot, but at that image size it's a little tough to see if you succeeded in balancing the pan vs the sharpness of the faster moving parts of the geese.
-David
"David raises a good point. . ." -- CDS
"Once again, David Raises a good point! :lol:" The Wise and Powerful CDS
Gear List | Proof I Use The Gear In My Gear List (not necessarily proof I use it well) (external link)
CanonCam
Apr 05, 2006 05:37 |  #5
Thanks everyone. Great help! This was taken in late evening. I thought there was still enough light, but I agree with the underexposure. For stuff like this, do you all use Tv and set your shutter speed or do you use Av or M? I wasn't sure about manual mode since I knew these geese were going to fly into the sun. Does that sound right?
Nidz
Apr 05, 2006 06:51 |  #6
Also don't crop the tips of the wings out.
Stop or I'll Shoot!
10 Years on POTN Forums!
Canon 350D | 70-200f/4L | ef35-105mm | ef100-300mm | 50mm f1.8 etc..
Some of my Photos (external link)
Robert_Lay
Apr 05, 2006 09:18 as a reply to  @ CanonCam's post |  #7
It takes a lot of experience to use both manual focusing and manual exposure.
However, in the long run, it will be worth the work to get there because it will be better than using Auto features.
My reasons for saying that are primarily due to the abysmal lack of intelligence on the part of lightmeters (they are dumb as a rock) and the fact that Auto Focus is too slow and is too dependent on good light and a contrasty subject with lots of detail.
Bob
CanonCam
Apr 05, 2006 12:27 |  #8
Makes sense, Bob. I am finding this rings quite true especially the loss in autofocus speed when the light is not the best. Again, thanks for the help!
Cam
859 views & 0 likes for this thread, 5 members have posted to it.
What needs fixin?
1581 guests, 115 members online
