FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 05 Apr 2006 (Wednesday) 13:36
Custome settings
Mike ­ T.M.
Apr 05, 2006 13:36 |  #1
The studio I work at has been balancing off a white card instead of a grey card, and I've noticed when we use this sky blue backgroung and I've customed balanced at 8@125the (INVALID EMAIL) the images look blue, like their dead, but when I switch over to the flash setting the images produce a red tint to them. What am I doing wrong or should I tell the studio to shot a grey card?
queenbee288
Gallery: 17 photos
Joined Dec 2004
Apr 05, 2006 18:30 |  #2
When you switch over to flash you have to do the custom wb again. You have to do it for whatever light you are using. probably not much difference between white and gray card.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 05, 2006 22:43 |  #3
Gray Card…White Paper. What’s best?
https://photography-on-the.net/forum/showthre​ad.php?t=58677
dmp-potn
Apr 05, 2006 22:51 as a reply to  @ PhotosGuy's post |  #4
Hello,
I use one of these:
http://www.rawworkflow​.com/products/whibal/i​ndex.html (external link)
There's an obviously biased write-up on that page that suggests things to look for in a good white balance tool.
We've been happy with whi-bal so far. The hardest part is just remembering to use it. :-)
-- David
chtgrubbs
Joined Jul 2003
Apr 06, 2006 22:05 |  #5
If you use a white card, then one of the channels can be higher without you knowing it because it appears to be blown out, causing a color cast. But if you use a grey card you can see if one channel is just a few points off from the other two.
Mike ­ T.M.
Apr 08, 2006 09:27 |  #6
I set-up the lights first, then set the wb at f8@125 or aoround there. We've has the WhiBal cards for about a year now and really never used them. I just got done looking at the site and did some at home test. See, the thing was about a year ago we were shooting raw for everything and just tookk for every in post production, then a rep from a color lab said we should shoot jpeg and now when doing so in a controled lighting the color seems to be off a little. really only when we use that particular background, which I hate.
PhotosGuy
Joined Feb 2004
Apr 09, 2006 09:53 |  #7
What if another rep said to only shoot film? I'd go back to RAW, but deliver a jpg to that lab?
Mike ­ T.M.
Apr 11, 2006 06:32 |  #8
Well, I went back to shoot the whibal cards (in raw) and it seems to be working alright. It's the jpeg shooting that I get nervous about, and it more to do with certain colors. I changed some setting in the mark II that had to do with the color tone, saturation in hoping that will make a difference.
PhotosGuy
Joined Feb 2004
Apr 11, 2006 08:10 |  #9
If you've got a MK II & don't have an immediate deadline to meet like the Sportshooters like Gavin, KennyG & IndyJeff have, I wouldn't diddle around with jpgs. Which is what your doing now. Change this, change that?
While you're doing that, I can gave a kick a** jpeg converted from the RAW file in less time. ;)
Mike ­ T.M.
Apr 11, 2006 15:06 |  #10
So you shoot raw all the time even on sports?
PhotosGuy
Joined Feb 2004
Apr 11, 2006 20:27 |  #11
Yes, "Digital negative"! Try this for yourself. Shoot a Raw + Max Jpg. A max jpg from my 20D is 2,754 KB. The exact same shot with the jpg extracted from RAW is 4,315 KB. (Your sizes will vary depending on how busy the subject matter is.)
Whatever info is in my extracted jpg is a lot more detailed than what comes right out of the camera.
Granted that you get a much bigger file from your MK II, but why throw those extra bits away?
This post shows that you can see the difference in detail even in a small web jpg: post #58,
The original thread:
Auto White Balance - works really well (Actually it doesn't!)
Mike ­ T.M.
Apr 12, 2006 06:17 |  #12
Well, it started back with this rep.,from a local color lab, "saying why shoot raw,when you are in a controlled situation (lighting) shoot jpeg." We do a lot of memory mates in the area and the post production shooting raw just tookk a long time and space. Now, I shoot jpeg and raw on my own, but at the studio it more about time and space.
PhotosGuy
Joined Feb 2004
Apr 12, 2006 06:37 |  #13
The rep has a valid point, but is he a shooter? It's about personal preference & shooting freedom to me Mike, as I said in post #9. When I'm shooting, I don't like to have anything come between me & the process, like "Measurebating" a 1/2 stop exposure change or color balance etc. every time I add/change a light or set-up. RSP frees me from that, let's me get on with the job at hand, & I think I gain quality & save time in the long run.
Mike ­ T.M.
Apr 19, 2006 10:53 |  #14
thanks everyone I think we're going back to raw
3,483 views & 0 likes for this thread, 5 members have posted to it.
Custome settings
1059 guests, 103 members online
