Thread started 06 Apr 2006 (Thursday) 09:02
Default Preference Settings for DPP 2.1
caldgrp
Joined Feb 2002
Apr 06, 2006 09:02 |  #1
Forced to use Canon DPP for 30D Raw conversion, I was wondering about specifying DPP Preferences
Since my objective is the maximum quality, I changed the default to "Quality Priority" in Operating Mode and set luminance and chrominance noise reduction to high. Is there any downside, other than processing time, to doing noise reduction on all images, even if not needed?
Also the "Output Resolution Value" default is 350 dpi, with a generous range of 1 -60000 dpi possible. Does this Value refer to display, print or what?
hemuni
Apr 06, 2006 09:44 |  #2
In my experience the NR set to high is similar to that of in camera NR and it seems to adjust according to the amount of noise.
The amount is verry subtle and very good considering noise/deail, but this is subjective and i suggest you make your own tests.
You will not feel any difference in conversion speed.
For an explanation on DPI check this link:
http://desktoppub.abou​t.com …mediate/a/measu​re_dpi.htm (external link)
((¯`•.¸hemuni¸.•´¯)) 1000D • 85F1.8 • 50F1.4 • 28F2.8 • 18-55IS • YN565EX - POTN gallery
tzalman
Fatal attraction.
Apr 06, 2006 18:46 |  #3
You should be aware that any time NR is applied you pay a price in loss of detail. More NR, less detail. Part of being a photographer is deciding where to draw the line, just like sometimes you have to accept the higher noise of a high ISO in order get a sharpness-making shutter speed. Your photo, your decision.
Personally, (and provisionally) after playing around with it a bit, I've decided on: ISO up to 400, "No Luminence", "Low Color"; ISO 800, "Low/Low"; and ISO 1600, "High/High". This is in regard to an XT.
As for DPI, forget about it. It has meaning only for printing, and even there it's of limited use.
Elie
Elie / אלי
Raj
Joined Dec 2004
Apr 06, 2006 18:51 |  #4
Interesting, I am using DPP lately too, but I didnt tried NR in DPP at all, instead I just use Noise Ninja after DPP conversion to tiff/jpeg is done (tiff for important images or where futher editing is reqd, rest jpeg)
I have one batch of iso1600 RAW's to convert, I can try high & low settings combo to see how it goes :-)
1DX, 5D, 20D with BG E2, Sigma EX DG 8mm F3.5 Circular Fish Eye, EF 15 mm f2.8 fish eye, EFS 10-22 mm f3.5-4.5, EF 24-70 F2.8 L mark ii, EF 24-105 f4 L IS, EF 16-35 f2.8 L , Sigma 35mm f1.4 A, 50 f1.8 mkII, 50 mm F1.2 L, EF f85mm 1.8, EF 100 f2.8 macro, EF 135 F2 L, Sigma 70-200 f2.8 EX HSM, EF 70-200 f2.8 L, IS USM mark ii, EF 100-400 f4.5-5.6 L IS, Sigma 18-125 f3.5-5.6 DC, APO 1.4x, G3, Cheapy Velbon Sherpa 435, Slick Carbon Fiber, Speedlite 430EX and 580EX with stofen OM-EW
hemuni
Apr 07, 2006 06:43 as a reply to  @ tzalman's post |  #5
Interresting - i will do some more testing on this. Up until now i have not noticed any signifigant difference and in general find DPP NR very gentle, but i will investigate. Thanks for sharing.
Jack ­ W.
Joined Jun 2003
Apr 07, 2006 07:02 as a reply to  @ hemuni's post |  #6
I haven't used DPP in about a year, but when I received my 30D, I installed it so I could open the RAW files until updates are available for ACR, RSP and C1 LE.
I was pleasently surprised at how quickly it displayed the thumbnails (no waiting for them to be created like in the others).
I did a few conversions, and when I opened them in PS, they seemed a bit cleaner than I had been used to in the other apps with my 20D.
Since then, I've run the hack for ACR (which works fine) and did a few comparisons. I converted a few shots with both ACR and DPP, both with default settings.
While in no way was my test extensive,the DPP conversions were definitly a bit cleaner than the ACR conversions. And colors seemed more accurate in DPP, especially reds (ACR is known for reds that tend to look too orange).
Jack
20D, 30D, 500f/4L IS, 300f/4L IS, 300f/2.8L IS, Canon 1.4TC, Canon 2xTC, 70-300IS, 17-85IS, EFS 10-22, Sigma 150 Macro, 3021PRO, RRS BH-40LR, Gitzo 1325, full Wimberley Head v2, Wimberley Sidekick, and a bunch of other stuff. :-)
1,431 views & 0 likes for this thread, 5 members have posted to it.
1061 guests, 119 members online
