My wife's been in tears over this puzzle for weeks...
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
bewaretheblur Member 195 posts Joined Mar 2006 Location: Lake Placid, NY More info | Apr 08, 2006 08:22 | #1 My wife's been in tears over this puzzle for weeks...
Bodies: 1d mkIII, 30D, 20D,
Robert_Lay Cream of the Crop 7,546 posts Joined Jul 2005 Location: Spotsylvania Co., VA More info | Apr 08, 2006 08:36 | #2 Interesting composition. Bob
Robert_Lay wrote: Interesting composition. Considering the harsh lighting (extensive dynamic range), you were able to get a very good rendition. Did you use "Merge to HDR"? I actually have no clue what I'm doing when it comes to taking pictures. I'm not even sure what "Merge to HDR" is... Bodies: 1d mkIII, 30D, 20D,
Robert_Lay Cream of the Crop 7,546 posts Joined Jul 2005 Location: Spotsylvania Co., VA More info | Apr 08, 2006 13:56 | #4 No problem - you are doing great for someone who's just getting started. Bob
Robert_Lay wrote: No problem - you are doing great for someone who's just getting started. In a scene such as yours the brightest highlights and the deepest shadows must fit into a scale of values from 0 to 255 (black to white). If the range of brightnesses gets jammed into that number space improperly, you lose detail at one end of the scale or the other (sometimes at both ends). In such a case shooting in RAW mode greatly enhances your chances of saving detail where you want it before it gets committed to an end-use format, such as JPG. In extreme cases, "Merge to HDR" can take two or more separate images of the same scene and process them so as to take the highlight information from one, the mid tone region from a second and the shadow region from a third, combining them all into one image with the best possible apportioning of detail. Ah, that makes sense. Wow, is that Merge to HDR accurate? How much of it is automatic, and how much of it do you have to clean up after? Bodies: 1d mkIII, 30D, 20D,
Robert_Lay Cream of the Crop 7,546 posts Joined Jul 2005 Location: Spotsylvania Co., VA More info | bewaretheblur wrote: Ah, that makes sense. Wow, is that Merge to HDR accurate? How much of it is automatic, and how much of it do you have to clean up after? It is very much a two-step process. Bob
| Latest registered member was a spammer, and banned as such! 2047 guests, 97 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
