Thread started 09 Apr 2006 (Sunday) 19:56
Which Tripod to choose?
yamezbond
Apr 09, 2006 19:56 |  #1
I wonder if somebody can help me to get a new tripod for my canon 20d.
The one I had is not good anymore, I want to get somenthing that last longer than the regular tripods.
Also I wonder which is better.. the Tripod or Unipod?
Canon 20D
Canon EFS 18-55mm
Sigma 28-70mm F2.8-4 DG
Sigma 70-300mm F4-5.6 DG MacroFlickr (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Apr 09, 2006 20:03 |  #2
A quality tripod is a good investment. They are spendy $300. and up. The best ones will last longer than most of your equipment.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Spphotos
Apr 09, 2006 20:07 |  #3
I really love my Tiffen Magnum XL. Its really study but a bit heavy. I got lucky and only paid $30 for it from Ebay. They cost around $120 in stores
Shoot film or die
www.shpphoto.com
bolantej
Apr 09, 2006 20:20 |  #4
tripod for getting rid of any camera shake. monopod for tight quarters needing some extra steadiness. I have a Manfrotto 3021BPRO and a 488RC2 ballhead, and I love it. kinda heavy though.
kaitanium
Apr 09, 2006 20:20 |  #5
look up amvona.com and see what they got. then head over to ebay and search amvona.com as the member name and bid from there. dirt cheap. great quailty vs price.
a tripod is not better than a monopod or visa versa, its what you need it for
if you want something a little more expensive i suggest the manfrotto 3021 with something like a 466 head. but you gotta state what you shoot
LewisImaging
Apr 09, 2006 20:28 |  #6
what do you plan on doning with tripod/monopod?
i plan on hiking etc, so i got a light weight CF Feisol 3402N and a Manfrotto 488rc2 on the way. the feisol is quite nice. seems to be great quality.
Mikelangelo
Joined Nov 2005
Apr 09, 2006 21:03 |  #7
This is the one I'm drooling over: 190MF4 Magfiber Carbon Fiber 4-Section Tripod Legs - Supports 8.8 lb (4 kg) -- from Bogen/Manfrotto $275 from B&H Photo
It's very light and folds very short... so it's good for traveling. I just got an aluminum monopod from Bogen/Manfrotto. I got it for hikes and such. I also got a cheap head that only pivots on one angle...not my smartest move. I think I'll upgrade to the 488RC2 ball head by Bogen Manfrotto. I found the weight differnce between the aluminum / magfiber monopod wasn't that big, so I saved $150 and went with the aluminum. HTH.
Photoblog (external link)
7d::17-50 f/2.8::100 Macro
yamezbond
Apr 09, 2006 22:22 as a reply to  @ LewisImaging's post |  #8
I just want fast movement when I take pics, usually I take pics from birds or plants
Canon 20D
Canon EFS 18-55mm
yamezbond
Apr 09, 2006 22:25 as a reply to  @ Mikelangelo's post |  #9
I was checking some tripods and monopods, but seems to be a lot out there, which specs or brand I have to look for?
To be honest I wonder if there is some tripod that has some kind of ball where you put the camera and you can rotate to wheathever angle you want.
Canon 20D
Canon EFS 18-55mm
mbze430
Apr 10, 2006 01:06 |  #10
I personally have the Manfrotto 055MF4 (external link)which is one of the lightest. I carry my tripod everywhere, because I learned from early that you never know when you'll need it.
It is 2kg (4.4lb)
My Hub to my personal work (external link) (just click on the banners)
mbze430
Apr 10, 2006 01:09 as a reply to  @ yamezbond's post |  #11
For head I use the Manfrotto 486MGRC2 (external link). It uses hydrostatic to lock the ball, this head has a magnesium die cast body, a 2” Teflon coated aluminium ball which combined with specially designed tension surfaces provides movement as smooth as silk.
It has the best weight to Max weight ratio for heavy lens.
The ball head is about .6kg (1.3lbs)
As you can see my setup is only 5.8lbs, but can hold up to 23lbs which is plenty for up to 600mm f/4 IS (11.8lbs) or 400mm f/2.8 IS (11.8lbs) :)
ghocking
Apr 10, 2006 01:21 |  #12
Buying the Tripod is the easy bit, getting the right head is the hard part.
Geoff Hocking
G9|20D|40D|50D|5D|7D|1​DMkIIN
60 Macro|50 1.4|100 Macro|17-40 L|24-105 L|100-400 L|Sigma 18-200 OS
270EX|430EXII|580EX
Rey
Apr 10, 2006 01:32 |  #13
I have the Bogen Manfrotto 3001BD and 488RC2 ballhead. Good tripod, very steady and sets up in seconds. I got the 488RC2 because it had a separate pan lever, which comes in very handy.
Canon 5D MKII • BG-E6 • Canon EOS-M • Canon 85mm F1.2L II USM • Canon 100mm F2.8L Macro IS USM • Canon 16-35mm F2.8L II USM • Canon 24-70mm F2.8L USM • Canon 70-200mm F2.8L IS USM • Sigma 50mm F1.4 ART • Canon Speedlight 600 EX-RT • Canon Speedlite 580EX II • Canon Speedlite 430EX II • Gitzo 3530 • Really Right Stuff BH-55 LR
exerda
Apr 10, 2006 08:22 as a reply to  @ Rey's post |  #14
I primarily use my monopod when hiking or walking about, and have a Manfrotto 322RC grip-style ball head on it, which I have found to be quite an effective combination.
I just got a good tripod, a Feisol 3401N, which I have been very pleased with so far. It's light--just over 3lbs with the center column--and collapses down to under 22 inches (smaller than my monopod!), yet still is tall enough for me to use without hunching over (56 inches without extending the center column--so add the tripod head, battery grip or lens mounting ring, and camera, and it's just about right for me at 6'4"). Best, it cost $250, which gives me $150-$300 more to spend on other camera equipment than if I'd bought a different brand. :D
I have found, though, that I prefer a more traditional ball head on the tripod to the grip-style head I have and love on my monpod.
Canon 6D; 7D mkII; EF 500mm f4L II; EF 24-105mm f4L; EF 300mm f4L IS; EF 16-35 f2.8L II; EF 24-70 f2.8L II; EF-S 10-22mm f3.5-4.5;1.4x TC III; 2x TC III Speedlite 580 EX II
yamezbond
Apr 10, 2006 19:23 |  #15
I just got from ebay a AT 858 Professional Tripod by DynaTran for $78.00 whit the grip action ball head, I don't know if I make the righ choice but thats all I can expend for now.
Canon 20D
Canon EFS 18-55mm
6,461 views & 0 likes for this thread, 22 members have posted to it.
2870 guests, 180 members online
