Thread started 10 Apr 2006 (Monday) 14:27
HELP! brand new 30D---speck on viewfinder!!
Brodog2525
Apr 10, 2006 14:27 |  #1
please help me! my new 30D just arrived about 1 hour ago. so i take everything out of the box etc, put the lense on and all that stuff.
then i take a few photos and everything is going great.
then i go outside in the bright sunlight and look in the viewfinder, i see a small black speck to the above right of the focusing squares!
So i take 1 photo and i am very happy to see that the speck is not on the photo(i looked on the LCD screen and zoomed in)
So i go inside and first take off the skylight filter and its still there. i then use a can of air and try to spray out the speck from the viewfinder. (the place where you look in to take photos) but its still there. I then take off the lense and look through the viewfinder and its STILL THERE!!!!!
Is this normal somehow?????????
When i took the first 4 or 5 shots the speck was not there(at least I think it wasn't) but now the speck has just appeared.
has this happened to anyone??? the speck isnt on my photos when I put them on the computer(thank God) but what should i do!?
Canon 30D | 17-85mm EF-S with IS | 430EX Flash
50mm f/1.8 II | 18-55mm lens kit
70-200mm f/4 L
brodiehenry.smugmug.co​m (external link)http://www.BrodieHenry​.com (external link)
Double ­ Negative
*sniffles*
Apr 10, 2006 14:30 |  #2
Leave it there. It won't harm anything.
If it really bothers you, take the lens off and hold the camera upside down and pointed down somewhat (so that the focusing screen is visible. Hit that with a few puffs from a blower and remount the lens. With luck, the speck will be gone. You can repeat this a couple of times if need be. If it refuses to go away, it might be above the focusing screen in which case it's best to just leave it.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Brodog2525
Apr 10, 2006 14:32 as a reply to  @ Double Negative's post |  #3
you sure? im just really nervous thats all
and its kinda a medium speck i guess u could call it
70-200mm f/4 L
Lord_Malone
Cream of the Manpanties.....​... Inventor Great POTN Photo Book
Apr 10, 2006 14:36 |  #4
Thanks for clarifying that. ;)
~Spaceships Don't Come Equipped With Rear View Mirrors~
http://www.myspace.com​/chocolate_thai (external link)
Brodog2525
Apr 10, 2006 14:37 as a reply to  @ Double Negative's post |  #5
THANK YOU
the situation is perfect now.
i had tried the can of air before but i guess i didnt do it the right way
thank you double negative!
70-200mm f/4 L
hudsonch
Apr 10, 2006 14:40 |  #6
Most likely it is the dust on the penta mirror. Yeah, you can try to open it up and clean it - however it would be counter productive in most cases.
As long as the dust is not on the CMOS sensor you are OK.
Psychologically it is not the most pleasant moment to find a dust spot in your viewfinder. Just view this the other way - take a look at your old Nikon/Canon/Pentax/Con​tax/whatever SLRs, definitely you would find some dust in the viewfinder. Yet they still take good pictures if films are available!
:lol: Life is a box of cameras and lenses! - H.C. :lol:
Canon 350D & a bag of inexpensive used lenses
mbze430
Apr 10, 2006 14:47 |  #7
If I remember correctyl with my old 20D, should be the same as the 30D, the focusing screen is somewhat attached to the entrance to the viewfinder. There are ways to remove it, and than be able to access the area in the prism of the viewfinder. You'll have to search the net for that one.
My Hub to my personal work (external link) (just click on the banners)
Double ­ Negative
*sniffles*
Apr 10, 2006 14:54 |  #8
Be careful with that compressed "air" too - you're really much better off with a squeeze bulb type blower.
Glad you got it sorted - I hate specks just as much as the next guy. :D
Nightcrawler
Joined Jun 2004
Apr 10, 2006 14:54 |  #9
Don't worry about the dust in the viewfinder. I had some on mine once. I noticed it just went away on its own. It doesn't affect the pictures in any way.
Jason - Gear - Site (external link)
Lord_Malone
Apr 10, 2006 15:22 |  #10
Using Double Negative's method, I was able to get most of the dust specks out of the viewfinder. Hardly any dust visible at all now. A good thorough blast with a rocket blower once a week should do the trick in keeping the dust in the viewfinder to minimum. ;)
1,729 views & 0 likes for this thread, 6 members have posted to it.
1519 guests, 131 members online
