boomer3297 wrote:How can I keep quality when posting in forum????
I have it on highest resolution for an a610
You are essentially "at the limit". There is no way that I know of to have your image hosted on the forum and meet the picture size and file size guidelines and get any better quality. If you bump up the quality, you overshoot the file size. If you use a smaller than 800 pixel linear dimension, you can trade off the savings in file size for a higher quality in the compression. The only way that I know to improve on that is to add a second picture of about 1" x 1" size that is made as a full detail 100% crop of some critical region in the image. In that way the viewer gets the over view of the entire image but he also gets the 100% crop in which he can see the same exact level of detail in the portion of the picture that he would see if he had the original image file.
Regarding you posting, is f/5.0 your largest opening? If not, I think you might have opened it up and blurred the background even more without encroaching on the DOF needed for the blossom itself.
