Thread started 26 Aug 2003 (Tuesday) 16:15
Frames in PS
dewmuw
Joined Jul 2002
Aug 26, 2003 16:15 |  #1
Hi
Can someone please give me a hint about creating and using frames (ie wood effect) in PS7?
I found a default version for this:
Damian Waters
www.drumimages.co.uk (external link)
Conk
Joined Jul 2002
Aug 26, 2003 18:27 |  #2
Hi Damian
I have a filters unlimited plug-in that has a wood filter.
I can easily create a canvas the size I would want the frame for my intended photo to be with two different grain combo's and any colour combination.
I would use the rectangular marquee tool to cut out the middle of the photo (the size of the photo to frame) and paste the intended photo in place. There will be two layers. The layer with the frame can be beveled. The only thing with this is it wouldn't have the effect of mitered corners. That is a whole new ball of wax.
Here is a link to a tutorial that explains how to make some frames. The only thing is that I found there was some trouble performing some tasks in ps 7. I think it is geared around earlier versions.
http://graphicssoft.ab​out.com/cs/photoshoped​ges/ (external link)
Cloverdale Photography (external link)
Photos (external link)
More Photos (external link)
dewmuw
Joined Jul 2002
Aug 27, 2003 15:08 |  #3
Thanks Colin. I was hoping that there was an easy "you pres this button answer" but I guess that is me being lazy.
Damian Waters
barnold999
Joined Apr 2003
Aug 27, 2003 16:47 |  #4
Here is a tutorial I wrote up quickly for you
NOTE: I DID THIS IN PS6 BUT IT SHOULD BE SIMILAR IN PS7
1. Open the Photo
2. Convert to RGB (Image>Adjust>RGB)
3. Expand the canvas (Image>Canvas Size)
(I expanded to 4.25†play around until you find something you like)
4. Use the magic wand to select the expanded area
5. Create a new Layer
6. Expand the selection by one pixel (Select>Modify>Expand> 1px)
7. Choose a nice background wood color (RGB 194,140,87 is what I used)
8. Edit > fill > Foreground Color
9. Select > deselect
10. Now will be the texture (Filter>Noise>Add Noise)
Do it Monochromatic (I did it Gaussian 5% you can do more for deeper grain)
11. Now, select each segment of the wood with the rectangular marquee for a but joint and the polygon lasso for a miter joint…
12. Do a motion blur for the grain (Filter>Blue Motion blur)
At the top and bottom do 0 degrees
On the left and right do 90 degrees
13.To give some depth do Layer>Layer Style>Bevel and Emboss
Here are the settings I used
Style: Inner Bevel
Technique: Chisel Hard
Depth: 100%
Size 3px
Soften: 1px
Here is some extra I did:
1. Select > All
2. Edit > Copy merged
3. File > New (Make the new canvas bigger, I expanded by 1â€)
4. Past the image (Edit > Paste)
5. Layer>Layer Style > Drop Shadow (I just used the default settings)
dewmuw
Joined Jul 2002
Aug 28, 2003 03:50 |  #5
Brent
Thanks for the guide. I'll give it a go and let you know how it turns out.
Damian Waters
barnold999
Joined Apr 2003
Aug 29, 2003 16:20 |  #6
How did it come out?
carnagex2000
Joined Jun 2003
Aug 30, 2003 15:51 |  #7
I just got a plug-in (SPLAT!) for frames when using PS7 (also Auto/FX Photographic Edges)
http://www.alienskin.c​om/splat/splat_main.ht​ml (external link)
barnold999
Joined Apr 2003
Aug 30, 2003 16:15 |  #8
Plugins are cheating.
Conk
Joined Jul 2002
Aug 30, 2003 21:39 |  #9
Then the tutorial in this link will be right up your ally.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Aug 30, 2003 21:45 |  #10
Yeah but,.... :D
Here is link to an awesome forum with a host of the best framing actions I have used,.... All will work in Photoshop,. many will work in Elements too.
http://www.photozo.com …550ac1602074377​1dd02463ed (external link)
Sign up for the actions and stick around for all the cool info and people :)
CDS' HOT LINKS
barnold999
Joined Apr 2003
Aug 31, 2003 01:01 |  #11
Yah... well... um notice I wrote out a tutorial... I normally dont read tutorials... I make them up... tutorials aren't up my ally... they are a good way, though, for a complete novice to learn Photoshop (apposed to stanard PS books) in fact when I was a novice that is how I learned PS, with tutorials... but... after enough you figure out how to replicate stuff how you like...
Then I also believe non-native photoshop filters are cheating.
Conk
Joined Jul 2002
Aug 31, 2003 12:21 |  #12
Thanks CDS. Looks like a great forum.
Also, Damian,
Here is a download to some PS actions for wood frames.
http://www.outdooreyes​.com/photo41.php3 (external link)
3,191 views & 0 likes for this thread, 5 members have posted to it.
Frames in PS
1740 guests, 134 members online
