hi doing some outdoor shoots of friends soon ..(on grass). ill be using the 17-40L but the problem is at the moment i only have a 'cheap tripod' (hama gamma series) will this tripod suffice or will it cause more trouble than what it's worth, or would it be better to hand hold?
set up consist of....
canon 20d,580ex flash,17-40L lens, flash bracket and off shoe cord.
will the tripod handle this set up??
BTW if i use the tripod i will also be using the remote switch..RS-80N3
thanks phil
but you will be fine handheld too if the shutter is fast enough: not hard if light is Ok at this length IMO.
