Thread started 22 Apr 2006 (Saturday) 10:54
Freeware masking plug-in - GrowCut (Windows only)
DavidW
Apr 22, 2006 10:54 |  #1
In exasperation at trying to mask a very complicated shape against a very complicated background earlier, I found myself looking at the reviews of the various masking plug-ins available. I may buy Fluid Mask 2, but the steep price tag and short maintenance window are off-putting, and I'm not sure I'd get my money's worth.
This hunting around led me to GrowCut. Click here (external link) for the home page.
I've installed the Mask 1.1 package on my machine, and got exactly the result I was looking for with Photoshop after about an hour of careful adjustment. Once you work out how GrowCut works, it's easy to use. I suspect it won't do all masking tasks - for example, it will probably not mask hair against a background, but I'm very happy with the results I've got on this one image.
It's a bit crude, in that it only works in 8 bit mode and reduces the layer you're working on to a mask. I simply made a copy of the layer in a fresh document, reduced it to 8 bit, produced the mask, then copied it back into an alpha channel in my original 16 bit document. If you get the results you want, it's worth the 30 seconds of messing around to get the mask into your document.
As always, you can touch up the mask later with the brush and similar tools.
I'd be interested in other people's results.
David
jbkalla
Joined Feb 2006
Apr 22, 2006 11:22 |  #2
David, thanks for posting that it's a Windows-only plugin/mask. Often, I get excited about a plug-in only to find that it doesn't work on my mac.
Can we see the result?
John
flickr (external link) | G+ (external link) | Panoramio (external link) | InterfaceLIFT (external link)
Fujifilm X-T2
| 10-24 f4 R OIS | 50-140mm f/2.8 R LM OIS WR | XF100-400mm f/4.5-5.6 R LM OIS WR | 16-55mm f/2.8 R LM WR | 56mm f/1.2 R | 27mm f/2.8 Pancake |  Retina iMac & MBP
DavidW
Apr 22, 2006 11:38 as a reply to  @ jbkalla's post |  #3
This is work in progress at the moment - I've only masked it this afternoon.
See the two JPEGs. The first is the original image, the second is masked using the mask from GrowCut, a quick bit of manual touchup, and a two pixel feather (GrowCut masks have pixels either on or off, which is why it's no good for hair or similar).
I hope this shows that for some complex shapes, this freeware plugin is useful.
David
jbkalla
Joined Feb 2006
Apr 22, 2006 11:48 |  #4
Wow! Nice! I found one that supposedly does something similar, but forgot to bookmark it... I really hate tracing around an selecting for hours just to have a mask not work!
John
Fujifilm X-T2
DavidW
Apr 22, 2006 14:03 |  #5
If you have Photoshop (as opposed to a third party program) install GrowCut rather than GrowCut Mask. This works as selection plug-in (and appears on the bottom of the Select menu), avoiding the hassle I mentioned earlier about reducing the layer to a mask.
It's still 8 bit only, and pixels are on or off only (though you can easily apply a feather in Photoshop), but it's easier to use this way. Maybe it will be refined further, maybe not - but it still provided a solution to a masking problem I had today, as you can see from the results above. I've refined the mask further by hand, but the JPEGs above give you a good idea of what is possible.
David
NAisBEST
not few ..not really proud
Sep 11, 2006 15:31 |  #6
trying this at home :D
Canon5DMkII - Canon 70-200 f/2.8L IS - Canon 24-70 f/2.8L - 580 EXII -
3,868 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is vinceisvisual
1001 guests, 176 members online
