I purchased a used G2 for the sole purpose of converting to IR. I don't know if anyone knows the answer to my questions, but thought I'd ask anyway. I guess I'll find out soon enough! lol
1) Is the IR cut filter a laminated glass, coated, or is the entire glass impregnated? I guess my real question is can the coating or laminate be removed with acetone or simular solvant? I'd like to simply reuse the IR cut filter instead of cutting a clear piece of glass for the window since I have no plans on using the camera in any other fashion other than devoted to IR.
2) Is it necessary to even use a clear piece of glass at all for the window, will the CCD not seat properly with out it? once the IR cut filter has been removed the clear glass doesn't really serve any purpose other than maintaning the proper spaceing between the lens and CCD ?
