Ok, I got this lens used from someone at a SUPER cheap price, but it seems to have problems at longer focal lengths. It is the Sigma 70-300mm f/4-5.6 APO Macro Super.
At longer focal lengths the lens does not want to seem to focus on the object in the AF points. The lens will focus on the object, give the AF beep, and the AF point will flash, verifying a focus, but the object in the viewfinder is still blurry. It's not so much blurry as it looks like a double of the object. Kind of like if you cross your eyes a little.
Example: This was taken at 300mm, f/7.1, 1/1250s, iso200. This is a 100% crop as well.
Most of the other ones were taken at similar settings with at least a 1/1250" shutter, and you can see the propeller in the photos actually stopped, so I don't think it is motion blur.
| MIME changed to 'text/html' | Content warning: script |
I've gotten a lot of good shots out of this lens at smaller focal lengths, but I can't seem to get clear shots at or around 300mm. Should I try to contact Sigma to see what they can do? How much would a recalibration on this lens cost if they will do it? I don't want to be out a ton of money on this lens, but I also want it to use. BTW, this doesn't even happen all the time, only about 60% of the time. I can look through the viewfinder, the camera says it's focused, but you can obviously tell through the viewfinder that it isn't.
