Hey Trent,
yeah good to see some locals here, although all the other members are helpfull and friendly with advice.
PP is post production as you guessed, basically getting the image ready for printing or for the web. If your monitor is calibrated then the image on the screen should be the same as the final printed version.
If you print at home you will need to set you printer profile in the pp software you are using, or if you regularly print at a lab they can give you their printer profile.
HN....well that's my local Harvery Norman store (or Hardly Normal as many people call them), they have pro guality printing facilities.
All of my images are pp before printing, this way I know exactly how the final print should look and can ask for a re-print if they are not to my satisfaction.
Printing can sometimes be tricky as all labs/printers need to regulary calibrate their machines, if they do not calibrate often enough the colours will not be accurate.
I do not know of any labs near you, but if you check in your local directory I am sure you will find some.
If you are not planning on printing large quantities of images, setting up your printer/monitor/software at home can give you good results.
Hope this makes sense, its hard to explain it all briefly.
Marty
I Like Pressing Buttons......
