saqib wrote:
Maybe a silly question, but here goes:
Do all f numbers correspond regardless of which lens you are using? i.e. if you are using a 85mm 1.8 and use f2.0, will this need the same or less or more light (i.e. longer/same/shorter shutter speed) for correct exposure or, because it is a 1.8 capable lens, need less light (and so a faster shutter speed)?
Forget the lens rating, it is just a way of CONTROLLING the amount of light, as is the shutter speed, between the shutter speed and the size of the aperture you control the amount of light reachinbg the sensor or film. Any lens will require the same aperture setting for the same exposure
So yes its' the same for every lens
you can use the 'sunny f16 rule to help you visualise
i.e. if you have a bright sunny day with 100 ISO film the exposure will be ( near enough) 125 sec at f16
So ANY lens will be set to that or any variation of that i.e.
250th sec@f11
500th sec@f8
1000th sec@f5.6
2000@f4
4000@f2.8
etc.
A fast lens like the 85mm 1.8 might not be able to get a good exposure on a bright sunny day as the shutter speed might not be able to be fast enough at f1.8, so you might have to stop down
