Took this of my son and his puppy recently. I didn't have my flash on, but I like it. What do you think?
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
txdude35 Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | May 02, 2006 15:20 | #1 Took this of my son and his puppy recently. I didn't have my flash on, but I like it. What do you think?
Life is good. Photograph it.
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | May 02, 2006 15:29 | #2 |
Focus Member 72 posts Joined Jan 2006 Location: Montreal More info |
txdude35 THREAD STARTER Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | May 02, 2006 21:17 | #4 Wow. Much better. The original was pretty washed out, and I ran it through the velvia action and got the above result. I guess I'll have to revisit the PS. Life is good. Photograph it.
txdude35 THREAD STARTER Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | May 02, 2006 22:10 | #5 Here's a quick edit of another shot. I'm getting alot of color noise when I try to lighten it any more. I wasn't shooting raw because I knew I wasn't going to have time to do much processing. I'm sure regretting it now.
Hellashot Goldmember 4,617 posts Likes: 2 Joined Sep 2004 Location: USA More info | May 04, 2006 22:44 | #6 Permanent banI don't really like the no flash. You can hardly tell what kind of animal is there. Be smarter than your camera and realize when a fill flash is needed. 5D, Drebel, EOS-3, K1000
txdude35 THREAD STARTER Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | Hellashot wrote: I don't really like the no flash. You can hardly tell what kind of animal is there. Be smarter than your camera and realize when a fill flash is needed. Thanks for the comment. I was standing on a rock over a lake taking pictures of ducks when I turned around and saw them. It was a quick shot, but you're right-it wouldn't have taken any time to pop the flash up. Life is good. Photograph it.
shadowwolf Member 246 posts Joined Apr 2006 Location: New Mexico More info | Focus wrote: I tried a quick fix, here it is The origional shot doesn't look near as good as this edit...I'd be very interested in knowing how you made the change...I'm new to editing and find information on how these type changes are made very intersting. "Photography to me is the ongoing attempt to capture what my eye sees."....I say that...
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | shadowwolf wrote: The origional shot doesn't look near as good as this edit...I'd be very interested in knowing how you made the change...I'm new to editing and find information on how these type changes are made very intersting. Couldn't tell you how Focus did his, but to re-edit my version for brightness, all I did was duplicated the layer, set the blend mode to SCREEN, then erased the sky from the Screened layer only (to turn the now white sky back to blue), flattened, then added a little magenta. .
txdude35 THREAD STARTER Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | May 05, 2006 14:10 | #10 Thanks for the info, Radtech. I thought the fix by focus had way too much color noise, and I couldn't figure out how to get it right. I _really_ need to work on my PS skills along with my technical shooting skills. Now that I'm out of school I hope to have more time to devote to my photography. Thanks again. Life is good. Photograph it.
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | txdude35 wrote: I thought the fix by focus had way too much color noise, and I couldn't figure out how to get it right. To fix the chroma noise (green and red flecks) I used THIS TECHNIQUE .
Focus Member 72 posts Joined Jan 2006 Location: Montreal More info | I went with the quickest easiest way... I duplicated the layer, curve, then deleted the new sky...and the quickest easiest way is not always the best http://www.beiruttomontreal.com/
txdude35 THREAD STARTER Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | May 05, 2006 23:15 | #13 Thanks again to both of you. Life is good. Photograph it.
Focus Member 72 posts Joined Jan 2006 Location: Montreal More info | oops, I thought this picture was taken by Rad, my bad ! http://www.beiruttomontreal.com/
txdude35 THREAD STARTER Senior Member 838 posts Likes: 3 Joined Feb 2005 Location: El Paso, Texas More info | Focus wrote: oops, I thought this picture was taken by Rad, my bad ! It would have been right the first time if it had been taken by Rad. Life is good. Photograph it.
| Latest registered member was a spammer, and banned as such! 2349 guests, 102 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
