Thread started 19 Apr 2001 (Thursday) 06:20
Yarc : A RAW converter for G1, too
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Apr 19, 2001 06:20 |  #1
http://www.roava.net/~​henderbc/yarc.htm (external link)
It converts a RAW to TIFF, creates a 640x480 thumbnail and a webpage in 13.3 seconds in my Windows 2000 PIII 600 (dual)!
It's an MS-DOS prompt program, but in Windows (2000) it's easy to use it just opening the MS-DOS window, dropping Yarc.exe on it, hit space, drop the CRW on it, hit space and the few switches needed and hit enter.
Pekka
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
John ­ - ­ NJ
Joined Apr 2001
Apr 19, 2001 08:54 |  #2
Pekka:
Thanks for letting us know about this one. I tried it out and it works great. I will be asking Bruce Henderson if the log file Yarc creates which contains "a subset of the EXIF information" can be expanded to include all of the EXIF info like ZoomBrowser does. I'll post his response.
Thom
Joined Apr 2001
Apr 19, 2001 09:30 |  #3
You can also just drop a whole folder full of CRW files from Explorer onto a desktop "shortcut" icon and all files processed at "as shot" with .log .jpg .tif and index.html created in original folder.
I sent Bruce a G1 file yesterday as prev. version didn't work on G1, only D30 files, he came back with it within hours ... not too shabby :-) Good peeps.
BTW, Bruce's last comment re. log file, so far that's all he's been able to pull from the CRW, but working on it. All the exif is in the .jpg file, so need to use your Exif or Thumbsplus, etc. to view it
John ­ - ­ NJ
Joined Apr 2001
Apr 19, 2001 15:02 |  #4
Thom:
Can Exif or Thumbplus, etc., give all of the data that ZoomBrowser can?
Thom
Joined Apr 2001
Apr 19, 2001 15:37 |  #5
This is complete info as Exif displays from a Yarc produced jpg from D30 RAW file.
File: L:sparetwsphotod30test​s113CANONCRW_1324.jpg
Tag Name Value
010f Make Canon
0110 Model Canon EOS D30
0112 Orientation 1
011a XResolution 180.0
011b YResolution 180.0
0128 ResolutionUnit 2
0132 DateTime 2001:04:​19 13:12:59
0213 YCbCrPositioning ​1
8769 ExifOffset 178
829a ExposureTime 1/25​0
829d FNumber 8.0
8827 ISOSpeedRatings 1​00
9000 ExifVersion 0x30 0x32 0x31 0x30
9003 DateTimeOriginal ​2001:04:19 13:12:59
9004 DateTimeDigitized​ 2001:04:19 13:12:59
9101 ComponentsConfigu​ration 0x1 0x2 0x3 0x0
9102 CompressedBitsPer​Pixel 9.0
9201 ShutterSpeedValue​ 522046/65536
9202 ApertureValue 393​216/65536
9204 ExposureBiasValue​ 0/2
9205 MaxApertureValue ​194698/65536
9206 SubjectDistance 0​/1000
9207 MeteringMode 5
9209 Flash 0
920a FocalLength 48.0
927c MakerNote
Macro Mode Off
Self Timer Not Used
Flash Mode Off
Drive Mode Single
Focus Mode Manual Focus
Image Size Large
Program Manual
Contrast Normal
Color Saturation Normal
Sharpness Normal
ISO -
Metering Mode Evaluative
AF Point Selected None
Exposure Mode Av-Priority
Lens Attached 28-70 mm
White Balance Sunny
Sequence Number 0
Flash Bias 0 EV
Subject Distance 0
Image Type CRW:EOS D30 CMOS RAW IMAGE
Firmware Firmware Version 1.00
Camera Body Number 0c0000000
Owner Name Thomas Stevenson
Custom Functions:
Long exposure noise reduction Off
Shutter/AE-lock buttons AF/AE lock
Mirror lockup Disabled
Tv/Av and exposure level 1/2 stop
AF-assist light Off
Shutter speed in Av mode Automatic
AEB sequence/auto cancellation 0, -, + / Enabled
Shutter curtain sync 2nd-curtain sync
Lens AF stop button Fn. Switch AF stop
Auto reduction of fill flash Disabled
Menu button return position Top
SET button func. when shooting Change quality
Sensor cleaning Disabled
9286 UserComment
a000 FlashPixVersion 0​x30 0x31 0x30 0x30
a001 ColorSpace 1
a002 ExifImageWidth 16​0
a003 ExifImageLength 1​20
a005 InteroperabilityO​ffset 1494
0001 InteroperabilityI​ndex THM
0002 InteroperabilityV​ersion 0x30 0x31 0x30 0x30
1001 RelatedImageWidth​ 2160
1002 RelatedImageHeigh​t 1440
a20e FocalPlaneXResolu​tion 2160000/892
a20f FocalPlaneYResolu​tion 1440000/595
a210 FocalPlaneResolut​ionUnit 2
a217 SensingMethod 2
a300 FileSource 0x3
Thom
Joined Apr 2001
Apr 19, 2001 15:55 |  #6
One note re. exp. compensation or flash compensation in Exif is expressed as fraction, depended on how the camera is set up. If you have compensed 1/2 stop, then 1/2 means 1/2 stop. 2/2 is 1 full stop ... 3/2 is 1 and a half stop, etc. Same if set up for 1/3 stop compensation.
Focal length for the G1 is a weird fraction but, again it works ... just do the math to get actual (not 35mm equiv). I don't know why but D30 displays focal length correctly.
I'll have to take at look at ThumbsPlus again as my version is old since using Exif. I don't like the thumbnail files ThumbsPlus leaves all over the place :-( but if you like a light box type display with configurable info for the "slide" captions, it's very good.
Exif does not display .tif files, which may be a problem for some. I'm trying to see if that upgrade can be made.
John ­ - ­ NJ
Joined Apr 2001
Apr 19, 2001 16:55 |  #7
Thom:
I tried EXIFinfo and EXIFread. Neither could give me exif info from the jpegs created by Yarc. They could not give me exif info for jpegs created in photoshop. They DID give me exif info for jpegs created in the camera (not converted from raw).
Maybe I'm not using the software correctly.
Thom
Joined Apr 2001
Apr 19, 2001 19:53 |  #8
John - I have no problem with Exif for G1 files. I assume you are using Exif Viewer from my previous post?
http://members.nbci.co​m.../mkowalski.1/index​.html (external link)
Are you running Yarc on a directory that has BOTH the .crw and .tmb files created with each RAW file? You need both in the read directory. In fact, Exif will display the exif info from the .tmb file even before converted to .jpg by Yarc. So ... be sure to copy all the files from your camera's cf card, incl. thm files and browse that folder with Exif Viewer, the tmb should show up with exif info, when switching to thumbnails and trying full view, you'll see a little pic, just the 160x120 tmb file.
Once that works, run Yarc again, you should then have the exif info in the jpg. Exif will display the .thm file as well as your new .jpg (but not the .tif) so you'll have two lines for each file, but the jpg will be the larger size.
Use Tools > Options > Columns to pick the columns you want displayed. There are two ISO columns, use Canon ISO, in fact click on the Canon default and then fool with the ones that don't display info, sometimes one from the Standard (up at top of list) work better. You can drag column headings around to get in preferred order.
Good luck and let me know if any more problems
PS does not save the exif info with a .jpg ...
John ­ - ­ NJ
Joined Apr 2001
Apr 19, 2001 22:43 |  #9
Thom:
Bruce just e-mailed me. He's got a new version available that captures all the exif info. Damn, he's fast. I'll test it out tomorrow at work.
Thanks for the info about the files. I've never looked at the files in the directory because I've left it up to ZoomBrowser to download everything. I will look at it in the morning.
Thanks.
John ­ - ­ NJ
Joined Apr 2001
Apr 20, 2001 13:10 |  #10
Thom:
I tried Bruce's new version of Yarc and it does display alot of info. I also tried Exif again and I got it to work.
The problem I was having was the missing .thm/.tmb files. When you download using ZoomBrowser it changes the filename from CRW_0469.crw to 104-0469_CRW.crw. You only see the one raw file in the directory. It must store the exif data somewhere else in its own database file. I searched the drive and nothing came up with those extensions.
The microdrive had crw and thm files. I presume the tmb files are embedded somewhere. I used Yarc on them and the exif data was there. I sent Bruce some additional info. I'll let you know if he does anything with it. Thanks for the help.
Thom
Joined Apr 2001
Apr 20, 2001 14:21 |  #11
Sorry for confusion on file extension, I was just typing away not thinking (I think it is GraphicsWorkshop that uses .tmb or whatever) ... you're correct, it's the ".thm" files that you need to preserve when transfering RAW files.
BTW, that corrects my prior post, ThumbsPlus uses a .tDB file to store thumbs in the program's folder, DOES NOT leave extra files, that was GraphicsWorkshop. Delete the image in the app, but the .tmb file was left behind until you deleted with WE.
I bypass Zoomdozer completely, just use Windows Explorer and a USB CF reader to transfer entire folders off the cards, I get the files with original folders, file names, .thm, etc. intact. Files are kept in their original "1xxcanon" folder scheme on my drives, and whenever I modify a file I always just edit the name, leaving at least the image number intact, that way I can always go back to the original folders for my "negatives." Yarc makes that first extraction so nice, huh? So far I haven't burned any archive CD-R yet as I have (3) 60GB drives and auto-incremental-backup to a Unix server every night. I shuttle images I'm working on around on CF, Syquest cartridges and CD-RW.
Yep, Bruce is doing us all a lot of good. I like the expanded .log file now. Much better, and ID's custom functions, etc. for the D30 better than Exif (even thought it is there). I just don't know what to do with them, I see everything I need in Exif anyway.
Doug ­ Mick
Joined Apr 2001
Apr 20, 2001 14:35 |  #12
I tried Yarc 1.4.5b. What is the log file and where is it located? Is this the txt file that's generated for each image processed?
I've just been using the txt file generated from Chris Breeze's download utility for EXIF data. Should I be using a EXIF utility? What would the advantages be?
Thanks,
Doug
Thom
Joined Apr 2001
Apr 20, 2001 16:39 |  #13
Well, it doesn't line in columns too well here, but below is a screen capture of the target directory after running Yarc. I used yarc . so all options ran with output "as shot" in the camera. The .log files will open with Notepad if you double click the file in Explorer, or open from what ever text editor you choose. See capture from a .log file below.
Directory of L:sparetwsphotocanon_g​1tests100CANON
DIR 04-19-01 8:10a .
DIR 04-19-01 8:10a ..
CRW_0007 THM 9,640 04-17-01 2:16p CRW_0007.THM
CRW_0006 THM 7,944 04-17-01 2:08p CRW_0006.THM
CRW_0007 CRW 3,076,102 04-17-01 2:16p CRW_0007.CRW
CRW_0006 CRW 2,898,608 04-17-01 2:08p CRW_0006.CRW
CRW_0008 CRW 3,226,172 04-17-01 2:18p CRW_0008.CRW
CRW_0008 THM 7,880 04-17-01 2:18p CRW_0008.THM
INDEX HTM 411 04-20-01 5:27p index.htm
CRW_0006 JPG 90,836 04-20-01 5:26p CRW_0006.jpg
CRW_0006 LOG 653 04-20-01 5:26p CRW_0006.log
CRW_0006 TIF 9,437,440 04-17-01 2:08p CRW_0006.tif
CRW_0007 JPG 120,790 04-20-01 5:26p CRW_0007.jpg
CRW_0007 LOG 653 04-20-01 5:26p CRW_0007.log
CRW_0007 TIF 9,437,440 04-17-01 2:16p CRW_0007.tif
CRW_0008 JPG 95,306 04-20-01 5:26p CRW_0008.jpg
CRW_0008 LOG 649 04-20-01 5:26p CRW_0008.log
CRW_0008 TIF 9,437,440 04-17-01 2:18p CRW_0008.tif
16 file(s) 37,847,964 bytes
Log file contents:
File Name: L:sparetwsphotocanon_g​1tests100CANONCRW_0006​.jpg
Camera Model Name: Canon PowerShot G1
Shooting Date/Time: 2001:04:17 14:08:58
Shooting Mode: Manual
Tv (Shtter Speed): 1/250
Aperture: 8.000000
Metering Mode: Unknown
Exposure bias: 0/3
Lens: 7.000000 - 21.000000 mm
Focal length: 16.843750 mm
Image Size: large
Image Quality: RAW
Flash: Off
White Balance: Auto
AF Mode: Single
Focusing Point: Unknown
Contrast: Normal
Sharpness: Normal
Saturation: Normal
Image number: 1000006
Drive Mode: single frame shooting
MacroMode: normal
Owner name:
Firmware Revision: Firmware Version 1.01
I have no clue what to do with the log files as all this info is available in reading exif info from the .jpg generated by Yarc. Maybe to build a database? The D30 log file is more informative, and as Bruce recommends, check the output carefully for errors, Yarc is a work in progress.
As long as you run yarc "dot" or use the -l switch in the command line, you'll get this file along with other switch selections.
Which exif utility/browser you use is personal taste ... so far I prefer Exif Image Viewer, see my many references to it elsewhere.
John ­ - ­ NJ
Joined Apr 2001
Apr 20, 2001 16:52 |  #14
The log file is the text file with the .log extension.
Yarc is great for me because I don't use Chris Breeze's downloader. I have a 1GB microdrive with a card reader.
This is what Yarc has done for me:
1) I do not need ZoomBrowser any more.
2) I can now download the raw files (.crw) and the data files (.thm) directly to my hard drive using the card reader. Very fast!
3) Yarc can create a whole directory's worth of jpegs at 640x480 or smaller and place them on a web page for viewing. It also creates the .log file with the exif data (camera settings). You can use the log file to set up your own database of your photos. I imported a few into a spreadsheet and it worked fine. Or you can use an Exif reader.
4) Since I'm keeping the .thm files I can now import the raw file directly in to Photoshop using the twain driver. I don't need 9+MB tiff files cluttering up my hard drive any more.
Note: I could not import a raw file that was downloaded using ZoomBrowser because ZB would not keep the .thm intact on the hard drive.
What a great day!!!
Bruce Henderson has been very responsive to my requests for minor modifications. So responsive that he makes the changes the same day. Amazing customer service. The guy should work for Disney.
Thanks and good luck.
Doug ­ Mick
Joined Apr 2001
Apr 20, 2001 17:33 |  #15
Thom,
Thanks for that explanation. Everything is very clear now. I guess I'll have to play around with it to see how to organize the Exif data....as you said perhaps into a database.
One last question:
Is a new HTML file generated each time you run Yarc or are new 640 x 480 jpegs just added to the existing HTML file in the directory?
Doug
19,023 views & 0 likes for this thread, 15 members have posted to it.
1052 guests, 104 members online
