Thread started 09 May 2006 (Tuesday) 19:42
RSP does not recognize my CR2 files
BearLeeAlive
All butt cheeks and string.
May 09, 2006 19:42 |  #1
I have loaded RSP onto a new machine and entered the key and all, but it does not recognize any RAW images.
I know it is likely some simple thing, but a simple thing is how I feel as I can't figure it out.
Any ideas?
-JIM-
BearLeeAlive
May 09, 2006 20:33 |  #2
I have now tried rebooting my PC, reloading the program and even threw in a couple of bad words. Still nothing.
-JIM-
BearLeeAlive
May 09, 2006 20:40 |  #3
I found I can open the directory a RAW file is in in My Documents, right click and 'Open With' RSP and it works fine, I just can't access them through the RSP directory.
Very confused.???
-JIM-
goatee
"nice but dim"
May 10, 2006 07:53 |  #4
Have you tried the pixmantec forums? They're pretty good at answering queries there.
D7100, 50mm f/1.8, 18-140mm f/3.5-5.6, 70-300mm f/3.5-5.6 VR, SB800
https://photography-on-the.net/forum/showthre​ad.php?t=552906flickr (external link)
BearLeeAlive
May 10, 2006 08:05 |  #5
I did post the same thing there.
As well, last night I sent an email to pixmantec with the issue. I was just hoping one of the photo guru's here would have a quick solution.
Hopefully I will hear from someone there today, I had been putting off processing pictures for quite a while, now I have to get a bunch done before Friday. I don't think I have even used it since I set up this new computer a month ago.
-JIM-
Wilt
May 10, 2006 11:45 |  #6
You must have some setup issue. I've been successfully using RSP to open my 20D RAW files since November/December when RSP became available, all without having to resort to Right Click 'Open with'.
BearLeeAlive
May 10, 2006 12:08 as a reply to  @ Wilt's post |  #7
Me too. I have been using RSP since it came out with great success, it is since I loaded it on this new computer that it won't work. I even tried reloading it, maybe I should remove it completely and try reloding it. I still have not heard anything back from pixmantec.
-JIM-
Wilt
May 10, 2006 13:40 |  #8
<<it is since I loaded it on this new computer that it won't work. >>
Does your new computer have a different operating system than the old computer? Maybe there is a glitch caused at the O/S level
hemuni
May 10, 2006 13:48 |  #9
Just a thought - make sure you are on the "All" tab.
((¯`•.¸hemuni¸.•´¯)) 1000D • 85F1.8 • 50F1.4 • 28F2.8 • 18-55IS • YN565EX - POTN gallery
BearLeeAlive
May 10, 2006 14:11 |  #10
Both PC's were using XP Pro.
I am using the 'All' tab. I am attaching the error message that shows when I click on a folder that definitely contains CR2 files. I even tried opening a RAW file right from the card reader fresh outta my camera with the same results.
-JIM-
EOSAddict
Book Committee Immortal
May 10, 2006 14:24 |  #11
Have you tried latest version of RSE see if it does the same?
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
BearLeeAlive
May 10, 2006 14:37 as a reply to  @ EOSAddict's post |  #12
Good call, I downloaded and installed RSE as I had not set it up on this PC yet and it works fine.
Now I just need to figure out why RSP will not do the same.
-JIM-
SuzyView
May 10, 2006 14:38 |  #13
Don't tell me this, I'm starting to use Raw Shooter. Fix it quick!
BearLeeAlive
May 10, 2006 14:48 |  #14
Is there any chance that some file in FSP became corrupted and does not get permanently deleted when I used the 'Add/remove' tool? Maybe somehow I need to purge all traces of RSP before I reload it.
This whole ordeal is more proof that the more I learn the less I seem to know.:D
-JIM-
EOSAddict
May 10, 2006 14:58 |  #15
I had a similar problem with PSE3 a while ago when it kept locking up. I ended up finding out about an obscure ref file that gets corrupted but doesn't get deleted when you uninstall. Try an explorer search for all RSP-type files. Have you cleaned your registry? What version/build of RSP do you have?
Al
2,579 views & 0 likes for this thread, 7 members have posted to it.
1613 guests, 141 members online
