Having browsed through the Powershot website yesterday, I found the specifications of the Pro90IS to be having
An AF Lock feature (?!)
and 1 AF Focussing point.
Does anyone know how do I activate AF lock and exactly which is the 1 AF point?
wenyao Mostly Lurking 19 posts Joined Jan 2002 More info | Jan 06, 2002 22:09 | #1 Having browsed through the Powershot website yesterday, I found the specifications of the Pro90IS to be having
GaryBerg Junior Member 29 posts Joined Jul 2001 More info | Jan 09, 2002 11:44 | #2 You lock AF by pressing the shutter button half-way down.
mlfrancis Member 112 posts Joined Dec 2001 More info | Jan 09, 2002 20:53 | #3 The 1AF point means there is one autofocus point, most likely the center of the viewfinder/LCD. The G2 (probably other, but this is the only one I have) can have three different autofocus points: center, left, right. Most SLRs today have 5,7, maybe more autofocus points and they usually pick the point that is covering the closest object to you. More AF points usually make it easier to frame your subject off center.
Wildman Member 172 posts Joined Nov 2001 More info | Jan 10, 2002 01:22 | #4 To lock the exposure setting, press the shutter halfway, then press the * button. It'll hold the settings till the shutter is pressed all the way down to take a picture.
Jan 10, 2002 11:21 | #5 I don't think the Pro90IS has a central focussing point. There are times when it will not lock on the central target in focus at all; according to Botzilla's website, it (and the G1 as well) uses a contrast-based AF system, and not a center AF sensor? can anyone confirm this?
| Latest registered member is Niagara Wedding Photographer 1328 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
