1/25, f8, 55mm, Av mode, tripod used, shot at 5:30pm.Sleepy Hollow NY.
Any thoughts?
MikeR Goldmember 4,319 posts Likes: 7 Joined May 2006 Location: 06478, CT More info | May 10, 2006 22:01 | #1 1/25, f8, 55mm, Av mode, tripod used, shot at 5:30pm.Sleepy Hollow NY. Mike R
May 10, 2006 22:12 | #2 Honestly ....its a litte flat looking to me if that makes any sense.....the shadows are too light...if it was not for that it would be a nice photo. Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
May 10, 2006 22:18 | #3 Thanks Rosco, The original was shot in RAW and my fear was that I was leaving the shadows too dark until I came up with this, Maybe I need to take another look at one with darker shadows. I still have a lot to learn about when to stop editing an image. Mike R
jbkalla Goldmember 2,831 posts Likes: 1 Joined Feb 2006 Location: Elizabeth, Colorado, USA More info | May 10, 2006 22:49 | #4 This would be a gorgeous pic in the fall... John
mbze430 Goldmember 2,454 posts Joined Feb 2005 Location: Chino Hills More info | May 10, 2006 23:32 | #5 with a fall color filter set, you can make it look fall... or just do it in photoshop Gear List
May 11, 2006 16:03 | #6 jbkala - thanks for the suggestion. I took this while at work and no longer work inthat area but it will be worth the drive back in the fall. Mike R
Hellashot Goldmember 4,617 posts Likes: 2 Joined Sep 2004 Location: USA More info | May 11, 2006 17:56 | #7 Permanent banGood idea, but too much clutter in the forground blocking your subject. Possible move to the left to get around those trees and fence. 5D, Drebel, EOS-3, K1000
tcguy519 Member 99 posts Joined May 2004 Location: Twin Cities More info | May 11, 2006 18:43 | #8 I agree with the others. It's kind of flat and boring. The fence in the foreground should be removed. It would be much better in fall with some color.
May 11, 2006 19:26 | #9 Hellshot & tcguy519, Thanks for the feedback, I will get back there in the fall. when this shot was take I was limited because it is a historic site, which was closed and had security fences. I agree about the the trees and clutter in the forground, thanks for pointing it out. But I thought I was adding foreground intrest by including the fence. Do you think it should be totally removed?, When I go back I will be able to get many POV. Mike R
| Latest registered member is zachary24 1462 guests, 142 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
