Thread started 15 May 2006 (Monday) 06:45
Bouncing flash in a church?
song4themoon
May 15, 2006 06:45 |  #1
Since I just purchased the 580EX I still need to learn lots about how to use it.
During the ceremony inside the church do you rather bounce the flash on the (usually very high) church ceiling or do you point the flash straight on. I am thinking that straight on will cast to harsh of a shadow?
Also, forgive my ignorance, but can I set this flash to a lower setiing somehow so that I can use it only to fill in my otherwise no flash pictures? Do you know what I mean...
Sometimes when I shoot no flash and I take the widest aperture and slowest shutter I can do without shake (1/60th) it is still a bit to dark. But adding a full power flash would be too much. I want to preserve the look of a no flash pic by just adding a bit extra light. Is that possible with this flash?
www.forever-yesterday.com (external link)
Gear: 2 Canon 1Ds Mark II, 2 Canon EOS 20D , 580EX flash, Canon 70-200L 2.8 IS USM, Canon 17-55 2.8 IS, Canon 24-70L 2.8, CanonEF 100mm 2.8 USM, Canon EF 85mm 1.8, Canon EF 50mm 1.8, Sigma 20mm f1.8, Peleng Fisheye, 3 AB 800 w/ Pocket Wizzards
tim
Light Bringer
May 15, 2006 07:38 |  #2
You can set the FEC on the camera body or the flash (flash exposure compensation), that should do the job. Thing about fill is it's not going to help slow shutter speeds, it just fills in shadows. If you have it firing out enough light that it's the main light it's going to be distracting. I don't use flash in ceremonies, I use an F2.8 lens, if that's not enough I use the 50mm F1.4 and stand closer. Actually I did use fill flash once, but that's only because I forgot to turn the flash off.
Bouncing in a church isn't practical either.
jamiewexler
Joined Feb 2006
May 15, 2006 10:32 |  #3
I'll offer the opposing viewpoint (so you can see that there are a few "right" ways). I almost always use a flash in the church - at least for the processional, recessional, and kiss - more if needed (and allowed). In a church, I am typically using my flash as the main light - not for fill (i.e. if I have enough light that I only need a little fill I'd rather turn the flash off).
Whether I bounce or not is a decision I make on a case by case basis, just like I would if I weren't in a church. Are the ceilings high enough/too high? Are they white? For cathedrals with very high, dark ceilings, I point my flash straight ahead, and try to balance the flash/ambient with a combination of high ISO/slowish SS.
The reason that I use a flash during the processional/recession​al is that the aisle of most churches is not as well lit as the altar (where I can get away with natural light). For most of the processionals, the back door of the church is open making me deal with a strong backlight. The flash fills the front.
The reason I use a flash for the kiss, is that I am usually at relatively slow shutter speeds during most of the ceremony when I am shooting available light. The kiss happens so fast, and is such an important moment that I don't want to risk an unusable shot due to my/the couple's movements.
As for FEC - to me it is the most important button on my camera when my flash is the primary light source. I ride it all day, making adjustments regularly based on what my histogram looks like.
Massachusetts Wedding Photographer (external link)
My blog (external link)
my facebook (external link)
my gear
song4themoon
May 15, 2006 10:36 |  #4
very interesting points Tim and Jamie, thanks
tim
Light Bringer
May 15, 2006 17:55 |  #5
I do a lot of what Jamie does, using flash for the processional/recession​al, but usually not for the kiss.
1,891 views & 0 likes for this thread, 3 members have posted to it.
1747 guests, 110 members online
