Thread started 15 May 2006 (Monday) 14:02
Lens question
NJBeacher
May 15, 2006 14:02 |  #1
I currently own a Tokina 24-200 3.5. It needs repair. If the cost is too high I am going to replace it with a new lens. I bought it and the camera (a 10d) used. My question is, is there an advantage to having 2 lenses that cover the range or a single lens. For example, getting 2 lenses like a 28-80 and a 70-200 vs the single lens at 24-200. It is more convenient to have the single lens, but do the lenses with a smaller range give sharper pictures then the single lens with the bigger range?
Thanks.
Double ­ Negative
*sniffles*
May 15, 2006 14:09 |  #2
Lenses with shorter ranges tend to be better than those with longer ones. The latter usually falls short somewhere. One benefit as you can attest to is that by having multiple lenses, you have a fallback plan should one go bust. Finally, multiple lenses tend to be brighter than one mega lens. Plus the lens hoods tend to be more effective...
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
1,171 views & 0 likes for this thread, 2 members have posted to it.
Lens question
1282 guests, 178 members online
