Thread started 16 May 2006 (Tuesday) 04:37
My first attempt at layers
35mm
May 16, 2006 04:37 |  #1
I have been told it is over exposed (the original) so I figured it was a good time to play around with layering and this nifty trick :)
superdiver
May 16, 2006 13:22 |  #2
I really have got to learn to do this...this is great!
40D, davidalbertsonphotography.com
Newbie still learning
IrishPatE
May 16, 2006 14:09 |  #3
That picture looks great! You did a brilliant job--can you explain how??
StealthLude
May 16, 2006 14:28 |  #4
There are like 3-4 different ways to get this effect. One is using a desaturated layer and erasing color layer till u get what u want. Thats prolly what he did above.
Better meathods including creating a layer mask, or using the mask tool and "painting" the desaturation. Even after that was done, you can use tools such as selective color and replace color to create / finish up work to give it very clean edges.
After that, hut/sat tools can be used to change the color of the object.
Its pretty simple once you get used to it.
[[Gear List]]
Skype: Stealthlude
35mm
May 16, 2006 17:19 |  #5
I had no idea how to do it, but my partner was very excited as he knew how.
He took the original picture and pasted it as a new image, gray scaled it, then copy and pasted it back as a layer. I then erased the b&w layer by hand
991 views & 0 likes for this thread, 4 members have posted to it.
2847 guests, 170 members online
