Recently bought a 300/4 IS used and like it alot. Just tried using it with my Canon 2X (1)which cancelled the AF. Ran a search but nothing popped up. If this is the case, then does it work with the non IS 300/4?
photodd Member 202 posts Joined May 2005 Location: san louis More info | May 16, 2006 09:16 | #1 Recently bought a 300/4 IS used and like it alot. Just tried using it with my Canon 2X (1)which cancelled the AF. Ran a search but nothing popped up. If this is the case, then does it work with the non IS 300/4? http://www.jaytoddphotography.com
05Xrunner Goldmember, Flipflopper. More info | May 16, 2006 09:21 | #2 depends on what Camera you have..I anything but the 1series wont do AF with anything smaller then f5.6 My gear
May 16, 2006 09:25 | #3 On a 20D. The f/5.6 makes sense since it works with my 70-200/2.8 http://www.jaytoddphotography.com
RonaldS.Jr. Prodigal "Brick" Layer More info | May 16, 2006 09:25 | #4 Yes, anything slower than f/5.6 won't AF on a non- 1 series. You lose 1 stop of light on the 1.4, and 2 stops on the 2x. Mac users swear by their computers. PC users swear at theirs.
LesterWareham Moderator More info | May 16, 2006 09:49 | #5 Yes the 1.4X will work on any body but the 2X will only AF on a 1 series body. The lens gives fair IQ with the 2X so it is worth seeing how well the MF works for you. My Photography Home Page
SamAlfano Senior Member 719 posts Likes: 1 Joined Jul 2005 Location: Covington, Louisiana More info | May 16, 2006 10:37 | #6 Check out David Chauvin's galleries at http://www.pbase.com/dgc_arts/south_la_birds
JuanZas Goldmember 1,511 posts Joined Aug 2005 Location: Madrid - ESP More info | May 16, 2006 14:14 | #7 In order to work with AF and a non-1 series camera with an f/8, you must tape the 3 pins to avoid send the real f/stop info to the camera and that avoids AF. Cheers
| Latest registered member is vinceisvisual 977 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
