Thread started 16 May 2006 (Tuesday) 17:40
High ISO Noise Trick
martin_welch
May 16, 2006 17:40 |  #1
Hi - first post to this group.
I read somewhere recently about a trick to eliminate noise on a high ISO shot. Basically the technique involved taking the high ISO shot, then taking another shot with the same settings but with the lens cap on.
The article (post? I'll be damned if I can find the original link) then went on to suggest that the second shot is used to create a mask to hide the noise in the first image.
Has anyone else heard of this (or did I dream it?) and if so, could you give me a clue as to how it's done?
coreypolis
May 16, 2006 17:46 |  #2
i don't know what the point would be. if the trick needed a black layer for combination purposes, then you could just create a black layer in photoshop
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
martin_welch
May 16, 2006 17:50 as a reply to  @ coreypolis's post |  #3
No - this was more than just creating a black layer. It had the noise 'pattern' on the second exposure.
Cheers! Martin
MJCfromCT
Joined Nov 2005
May 16, 2006 18:01 |  #4
I believe this is what you are looking for:
http://www.photo.net/l​earn/dark_noise/ (external link)
About halfway down the page on this link is a workflow.
60D | BG-E9 | 430EX | Sigma 17-50mm | Canon 100-400mm L | Canon 50mm f/1.8
Radtech1
Everlasting Gobstopper
Joined Jun 2003
May 16, 2006 18:02 |  #5
It is called "Dark Frame Subtraction" and ONLY works with raw images, not jpg because the interpolation of a jpg is different for every shot.. The dark frame must be shot at the same ISO as the original shot. Preferably at the same temperature. HERE (external link) is a primer on how/why it is done.
Rad
OK looks like I was beaten to the link by seconds.
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
jwwill0
May 16, 2006 18:03 |  #6
Yep, just about to post that exact same link! Anyway, second layer (dark frame) in photoshop needs to be set to "Difference".
~Josh
http://www.joshuawilli​amsphotography.com (external link)
Flicr: http://www.flickr.com/​photos/jwilliams_photo​graphy/ (external link)
martin_welch
May 16, 2006 18:21 as a reply to  @ jwwill0's post |  #7
Wicked!
Thanks folks. I'll give this a try tomorrow.
Cheers! Martin.
Jesper
Joined Oct 2003
May 18, 2006 09:31 |  #8
Did you know that newer Canon cameras (20D, 30D, 5D, 350D) can already do this automatically?
It's used when you make very slow shutter speed exposures. In the Custom Functions you can switch it on or off.
Canon EOS 5D Mark III
martin_welch
May 18, 2006 15:53 |  #9
I didn't know that - thanks for the info. Sadly won't help me with my ancient 300D.
Poe
May 18, 2006 21:28 |  #10
Are the noise patterns for each ISO always the same?
Nikon D750, D7200 | Nikon-Nikkor 14-24G, 60G Micro, 70-300E | SIGMA 35A, 105 OS, 24-105 OS | ZEISS Distagon 2.0/25 Classic, Apo-Distagon 1.4/55 Otus, Apo-Planar 1.4/85 Otus, Makro-Planar 2/100 Classic, Apo-Sonnar 2/135 Classic
Dave240
Joined Jun 2005
May 18, 2006 21:56 as a reply to  @ Jesper's post |  #11
What function is that? I'm assuming the 10D doesnt have it, as that is what camera the write-up is based on...
Canon 50D w/ grip
Peleng 9mm fisheye
Sigma 15-80mm f/2.8
Canon 50mm f/1.8
Canon 70-200mm f/4 L
JMHPhotography
May 20, 2006 06:20 as a reply to  @ Jesper's post |  #12
Yes... but if you turn it on, you have to wait approximately the same amount of time for the noise reduction as the actual shot. (i.e. if you have a 10 second exposure, you have to wait an additional 10 seconds for the file to write) This will render the camera busy without the ability to take another shot until it's done. Most cases this is ok... but one area where that could be bothersome is shooting long exposures on fireworks. Unless you don't mind missing a few bursts between shots.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
Radtech1
Joined Jun 2003
May 20, 2006 08:27 as a reply to  @ Poe's post |  #13
No - the noise pattern will vary depending on the ambient temperature when the shot was taken.
Rad
taygull
May 20, 2006 09:16 |  #14
So which function is it...I guess I could go read the manual. LOL
www.chrisfritchiestudi​os.com (external link)
McKinney, TX
Eagle
Gallery: 62 photos
May 20, 2006 17:35 as a reply to  @ taygull's post |  #15
CF #2 on the 20D.
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
4,467 views & 0 likes for this thread, 11 members have posted to it.
1745 guests, 110 members online
