Thread started 18 May 2006 (Thursday) 11:53
100-400 User opinons needed for faulty lens
evandavies
Joined Feb 2006
May 18, 2006 11:53 |  #1
Hi all,
Top image f5.6
bottom f9.5 (the sharpest for my copy)
I am going to return it for re-calibration as its still under warranty. Just wanted to see if anyone else has seen this.
MLU=ON
IR Remote trigger
camera on large beanbag with another on top (if you download the images and flip them you can see that the camera was perfectly stable)
These images are from top/left of frame but not at the very edge.
Notice the highlights around the window are defined quads in the f5.6 image.
The leaves have a definite ghost which I'm sure is not cam shake and its there on both images tho its a bit better at f9.5 due to longer DoF I guess.
Cheers
E:¬D
- Gallery - (external link)
= Gear =
Lens focuses the light,
camera records the light,
you make it art.
Jon
Joined Jun 2004
May 18, 2006 12:10 |  #2
Did you have IS turned off for these?
Jon
Cocker Spaniels
evandavies
Joined Feb 2006
May 18, 2006 12:15 as a reply to  @ Jon's post |  #3
Yes, sorry, forgot to say that IS was indeed OFF and I locked focus with AF then turned it to MF to take the shots so both images are using EXACTLY the same focus.
Cheer,
ED
E:¬D
= Gear =
you make it art.
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
May 18, 2006 12:17 |  #4
Then obviously there's something very wrong. Send it to Canon for fixing and/or calibration. I've never seen such a thing with either of mine, other than when I mounted it on a tripod and left the IS on.
Mac users swear by their computers. PC users swear at theirs.
Rumjungle
May 18, 2006 12:20 |  #5
That's unacceptable. Let me know how it is after you get it back.
Gear
peacock
May 18, 2006 12:21 as a reply to  @ Ronald S. Jr.'s post |  #6
Both show f5.6 :confused: are these crops ?
Just started populating a site with snaps @
www.3cakes.co.uk
evandavies
Joined Feb 2006
May 18, 2006 12:29 as a reply to  @ peacock's post |  #7
Ah, just figured out why... they both show 5.6 because I loaded the 9.5 into the 5.6 one to do a transparent comparison in Photoshop. I then had to resize as they were too big to upload so I cropped them together and saved each individually. So they were both using the 5.6 EXIF data.
Yes they are 100% crops with no post processing. Shot with 350D and internal settings to default. ie sharpness, colour, etc
Ed
E:¬D
= Gear =
you make it art.
BigBlueDodge
May 18, 2006 13:30 |  #8
What was the shutter speeds, because to me it looks very clearly like you had some camera shake going on. Look at the leaves in the first picture. On some you can see doubles as if the camera shook while the shutter was open. I can also see it in the second shot.
David (aka BigBlueDodge)
Gear
evandavies
Joined Feb 2006
May 18, 2006 14:04 as a reply to  @ BigBlueDodge's post |  #9
The first at f5.6 is 1/1000s
the second at f9.5 is 1/350s
I thought it was cam shake when I first got the lens but as I said in the first post, its not on a tripod but securely supported with no chance of wobble. There is no way it could have produced such shake at 1/1000s.
- Also notice that the direction of the "shake" is the same in both images (up and right). I think it would be highly unlikely to get the same direction of blur on two consecutive shots. The only thing I can think of that would have repeatable shake would be the mirror and that was not a factor as MLU was ON.
- and if you look at the highlights on the windowsil they are not blured but are in a quad pattern.
E:¬D
= Gear =
you make it art.
cfcRebel
May 18, 2006 14:21 |  #10
Can you post a resized version of the original image, uncropped?
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
evandavies
Joined Feb 2006
May 18, 2006 14:35 as a reply to  @ cfcRebel's post |  #11
Here is the 5.6 full frame resized.
I don't have the 9.5 full frame
Ed
E:¬D
= Gear =
you make it art.
Simon ­ Spiers
Joined Jan 2005
Location: Crawley Down West Sussex UK (SE of Gatwick Airport)
May 18, 2006 14:40 |  #12
The full frame picture looks fine? Looks like the focus has locked onto the car. See no problem if thats the case.
Canon EOS 20D /70D/450D/ Tamron SP AF 17-35 mm f 2.8-4 DI/Tamron
28-75mm f2.8 XR DI / Canon EF 100-400 USM IS L / Speedlite 580EX and Better Beamer/ Pentax SMC Takumar 50mm f1.4
peacock
May 18, 2006 14:50 as a reply to  @ evandavies's post |  #13
The "ghosting effect in the first is because of the 2 imges overlayed yes ? the second I guess is just blur because its focused on the numberplate and at f5.6 400mm at that distance you have a shallow dof . how does the numberplate look at 100%.
www.3cakes.co.uk
evandavies
Joined Feb 2006
May 18, 2006 14:53 as a reply to  @ Simon Spiers's post |  #14
Yes, the focus was in fact on the license plate. The problem is not so much the focus but the the aberrations which I think are making the image softer than it should be.
No, both images are crops as they came out of the camera
ED
E:¬D
= Gear =
you make it art.
evandavies
Joined Feb 2006
May 18, 2006 15:03 as a reply to  @ evandavies's post |  #15
The focus is on the first "O" and it is quite soft compared to other crops I've seen.
I think the softness is related to the aberations seen in the first post. It does get better at higher F-stops but I've seen crops that are sharper at f5.6 than mine at f9.5
This is the centre of the f5.6 image. Unfortunately I don't have the full frame f9.5 to compare. Its was a bit sharper but not alot.
Ed
E:¬D
= Gear =
you make it art.
8,888 views & 0 likes for this thread, 20 members have posted to it.
2698 guests, 166 members online
