Thread started 19 May 2006 (Friday) 18:36
30D, AF points, and the 580EX, 550EX and 420EX
PacAce
Joined Feb 2003
May 19, 2006 18:36 |  #1
Here's a little piece of trivia (or maybe it's more like an annoyance) I just discovered today. Do you have the 30D? Do you manually select AF points other than the center AF point? And, lastly, do you own the 550EX and/or the 420EX flash and use the focus assist lamp? If the answer to these questions is "Yes", read on.
Did you know that when you have the 420EX mounted on the 30D, the focus assist lamp will not light when you have manually selected the AF points marked with an "X" in the diagram below? In other words, you will have no focus assist from the 420EX when you are using the AF points marked with the "X" below.
Likewise, if you have the 550EX, you will not have focus assist for the AF points indicated below.
Only the 580EX allowed focus assist with the flash for all the AF points. I don't have the 430EX so I can't say how the focus assists works with that flash. Nor do I know if the 550EX and the 420EX behave the same on the 20D and the 5D. :confused:
...Leo
peacock
May 19, 2006 18:47 |  #2
Interesting , I confess I dont use flash much , but I will try it just so its not an issue if the need arises.
Just started populating a site with snaps @
www.3cakes.co.uk
dsze
Joined May 2004
May 19, 2006 19:13 |  #3
hmm... interesting. I wonder why?
-daniel
"Life is not measured by the number of breaths we take, but by the moments that take our breath away."
-Gear List-
BigBlueDodge
May 19, 2006 22:13 |  #4
Wow, never knew that. I'm really glad I spent the extra for my 580ex, because I use manually selected AF all the time when using small DOF.
David (aka BigBlueDodge)
Gear
Carzee
May 19, 2006 22:23 |  #5
How did you happen across this discovery?
...and I wonder what does it all mean for users of non-Canon flash?
Having a bad day? Feeling down? Bantar Gebang Attitude Enhancement Images (external link)
Curtis ­ N
Master Flasher
May 19, 2006 22:30 |  #6
Gotta be just a bug that will get fixed with the next firmware update, assuming Canon is aware of the problem.
Carzee - Send me your 30D, I'll try it with my Sigma flash and let you know. ;)
cdifoto
Don't get pissy with me
May 19, 2006 22:33 |  #7
I think that's just how the flashes are made and marketed. The 580EX being the top dog covers all focus points.
PacAce
Joined Feb 2003
May 20, 2006 07:24 as a reply to  @ cdifoto's post |  #8
Nope, I don't think so. When the 550EX was king, it worked fine for all the cameras that were availabe at the time. For example, on the 1DmkII, the focus assist of the 550EX works for all the 45 AF points. Since the 580EX came out about the time the 20D came out, I'm thinking that the 550EX wasn't working 100% on it, like it doesn't on the 30D, and that's probably the reason they came out with the 580EX to rectify that, along with adding new features. But this is just conjecturing on my part. :)
...Leo
Keiffer
May 20, 2006 09:40 |  #9
Funny you mention this but I don't believe my focus assist lamp works when I put my metz on the cam. I thought I had something off in the cam and just forgot about it, I don't use the flash that often so I just forgot about it. I will check it out later to see if it is just with certain af points.
http://kcschoeppler.fo​topic.net (external link)
3,071 views & 0 likes for this thread, 8 members have posted to it.
1613 guests, 140 members online
