Thread started 20 May 2006 (Saturday) 19:50
C&C - general wedding
staciecd
Joined Feb 2004
May 20, 2006 19:50 |  #1
I recently attended a friend's wedding and took my Rebel XT. Lighting was horrible and my pictures came out slightly grainy. What can I do to take these pictures to the next level.
Stacie
Digital Rebel XT 350 | Kit Lens, 50mm f/1.8 II, 17-40mm L, 70-200mm f4 L, 70-200mm f2.8 IS, 15mm Fisheye
Speedlight 580EX II, 2 PocketWizard Plus II
Stacie's Portfolio (external link) Updated Feb 2008 | Stacie on Flickr (external link)
staciecd
Joined Feb 2004
May 20, 2006 19:52 |  #2
Pictures 3 & 4
staciecd
Joined Feb 2004
May 20, 2006 19:55 |  #3
Pictures 5 & 6
staciecd
Joined Feb 2004
May 20, 2006 19:57 |  #4
Picture 7
35mm
May 20, 2006 19:59 |  #5
You have two shots there where there is just a butt and a cut off head. Any reason for that?
I don't know how to fix the grainiess. Is there a softness feature in any of your packages? These kind of shots are perfect for vaseline :D
ladybelle2k
May 20, 2006 20:10 |  #6
Noise ninja will do a pretty good job on taking care of a lot of the noise
Canon Equipment
www.printroom (external link).com/pro/williamsphoto
staciecd
Joined Feb 2004
May 20, 2006 20:27 as a reply to  @ 35mm's post |  #7
Just trying something different - being creative. I have about 200 of full bodies :-)
Sporto
Joined Jan 2003
May 20, 2006 22:22 |  #8
Need more information - what lens did you use? What were the settings? Did you use fill flash? Your camera is more then capable to take a good image. Maybe it is your experience or limitation of the lens used?
Konowledge of light is always good - especially with tough lighting situations.
Gord
GordWeber.com
newgenphoto
Joined Jul 2004
May 21, 2006 00:29 |  #9
Hi Stacie... I agree with some of the cropping issues. Just takes practice. I use to leave WAY to much headroom until I heard "Too much headroom" over and over... I hope you don't mind but I fixed the grain in one of the shots.
Jasen Master
J. Master Photography (external link)
My Gear (Needs updated)
JMP Blog (external link)
Facebook (external link)
tim
Light Bringer
May 21, 2006 06:03 |  #10
I like the idea, but i'm not sure you pulled it off. In #1 take a big step to the right if you can. #2 is ok but I don't like the two colors. #3 I don't see the point, no focus. The others are ok, nothing grabs me though. Also the exposures aren't very accurate. I like the ideas behind it, keep trying :)
staciecd
Joined Feb 2004
May 21, 2006 10:11 as a reply to  @ Sporto's post |  #11
Gord
I used the Rebel XT kit lens, ISO 400, no flash (didn't want to bother anyone), 1/160s at f22. I have very little expereince, which is why I need C&C - help is very appreciated!
staciecd
Joined Feb 2004
May 21, 2006 10:12 as a reply to  @ newgenphoto's post |  #12
That's great. How did you fix the grain?
Thanks!
topsyturvy6234
May 21, 2006 12:06 |  #13
If you can expose photos correctly at ISO 400, f/22, and 1/160, the lighting certainly isn't bad by any means at all.
Canon 20D
10-22 f/3.5-4.5
50mm f/1.8
24-70 f/2.8L
70-200mm f/2.8L
Phil ­ V
Joined Jan 2005
May 21, 2006 12:35 |  #14
I love the cake picture. Made me jealous, as my last wedding was in a cave and all the cake pic's needed flash. As others have said, the crop of some of the images is questionable. If you're not including faces, you have to be including something to look at, ie there needs to be a point to the picture, other than chopping the heads off 'for a different view'. 2 and 3 don't really have a subject, but 7 does.
The exposures would probably have been better handled by the green square, I've never shot a wedding photo at f22, can't see why I ever would. No 4 would have been good if you'd opened up the lens so the background was thrown out of focus.
I've known photographers work from a cheat sheet for apertures, f2.8 for a person, f5.6 for a couple and f11 for a group, this is a start point but you'd need to learn when it won't work. I don't usually do C&C but I felt I had to comment on the f22 thing.
website: South Yorkshire Wedding photographer in Doncaster (external link)
Twitter (external link)Facebook (external link)
newgenphoto
Joined Jul 2004
May 21, 2006 14:47 as a reply to  @ staciecd's post |  #15
Thanks!
Just ran the pic through Noiseware Pro - Very low settings as well.
Jasen Master
2,267 views & 0 likes for this thread, 9 members have posted to it.
1745 guests, 110 members online
