It may take a couple of races to get things just right, but here's where I'd start:
marysia wrote:very very fast dog racing. typical shot(very very average-just for example):
They will be outside this time so I hope of doing better job than the last time.
Have the following questions:
1. Which lense: 70-200 mm f/4 or 50mm f/1.4? It is going to be very sunny day. I can get very close to the hurdle.
70-200 - f/4 on a sunny day is fine. I'd bump the ISO up to 400 though, as Stealthlude suggested.
2. What settings? Would you chose AV mode and go for f/4 for zoom lense and f/1.4 for 50 mm lense with ISO 100? Or, would you rather prefer TV mode?
As long as it's sunny, I'd use Av, ISO 400, and keep the aperture around f/4 - f/5.6. Watch your shutter speed, but it should still be OK in bright conditions.
3. Is it OK to use One Shot and pre focus on the hurdle or should I be using AI Focus? AI Focus seemed difficult to me the last time. I want to get as many JRTs jumping at the same time over the hurdle so I use the first one(hurdle). I barely have enough time to follow dogs leaving starting box. However, if I try to use One Shot I do not necessarly get dogs in focus even if the hurdle is in perfect focus.
I'd try a few each way. First, AF on the hurdle and then set the lens to manual. If you can keep the shutter speed up, stop the lens down a bit to enhance DOF. I'd also do a few in AI Servo, using a single focus point (probably the center one as it's the best one) and track one dog as it approaches the jump. Hold the shutter 1/2 way to keep the camera AF system tracking it, and then release at the right moment.
4. Is AI Servo works OK with burst mode?
Yes
5. what metering mode would you recommend for hurdles?
Depends on the background. Evaluative is relatively safe, but a high difference in brightness between the subject and background might give you problems. If it does, use something more selective like partial or spot metering.
Generally, the center AF point is the most sensitive sense it's a cross-type sensor. But if you subject is going to be towards the right of the frame or the left, select one of the AF points that matches the dog's position.
thanks. Your input would be greatly appreciated,
m
