I took the setup pic for myself, posting it and a few examples of groups with strobes because I thought people might be interested. Beware not to use this setup for big groups else faces of people in the rear will be in shadow - in that case put one strobe directly over the camera. I had no big groups so no problem.
In general I love strobes for group shots, if there's time to set them up. I usually arrive early, set them up, test them, meter them, then put them out of the way. I set them up in a few minutes for the group shots, stash them again, then tear them down after i'm done for the day.
Setup
Example group pic
Example boys pic
Example bride pic (single AB800 turned down to about 1/16th so I can use F2 or so)
The lesson learned at this wedding - using a tripod means your photos will be level and you so you don't need to manually rotate each one, doh!
