I just had my sensor cleaned canonand I don't even recall changing the lens in the last month (since it's been cleaned). Take a look at the dots in the upper right corner. Is that sensor dirt? What should I do? THanks.
islandphoto Goldmember 2,358 posts Likes: 1 Joined Mar 2006 Location: Maui More info | May 25, 2006 22:26 | #1 I just had my sensor cleaned canonand I don't even recall changing the lens in the last month (since it's been cleaned). Take a look at the dots in the upper right corner. Is that sensor dirt? What should I do? THanks. - Joanna
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | May 25, 2006 23:15 | #2 I'd 99.9% for sure say its sensor dust. Best solution is to learn and clean it yourself or edit it out in post processing.
HectorsGTI Senior Member 399 posts Joined May 2005 Location: Grand Rapids, MI More info | May 25, 2006 23:22 | #3 I use a rocket blower which USUALLY gets it out. Just remember to hold you body with the lens hole facing down. If that doesn't work I use a visible dust brush I purchased from bhphoto.com. That REALLY does the trick. It's not rocket science to blow the dust off your sensor once in a while. Once you do it a few times you'll be like "I sent this to canon for this? WTF was I thinking?" Hector
calicokat Cream of the Crop 14,720 posts Likes: 2 Joined Oct 2005 Location: Southern California More info | May 25, 2006 23:28 | #4 Get used to it. Happens even if you do not change lenses. Just a way of digital. Get a rocket blower and blow dust off your mirror and sensor from time to time. You should try using a 100-400L, dust machine. "You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife
nation Senior Member 906 posts Joined Jun 2005 Location: Sydney, Oz More info | May 25, 2006 23:37 | #5 Yeah some lenses are notorious for sucking in dust as your zooming so you can still attract dust without changing lenses. As mentioned above give the rocket blower a go first. Although it's designed to keep condensation out of its body give it 5 to 10 squeezes away from your camera to ensure none has settled before unleashing it on your sensor. If that doesn't work then go onto the copperhill method. 7D and lenses.
kmb Senior Member 808 posts Joined Feb 2006 Location: Jyväskylä, Finland More info | May 26, 2006 02:48 | #6 I'd say it's because your sensor chamber is dusty. The mirror throws the dust at the sensor. Some cameras are dustier than others - I'm not sure why this is - maybe differences in production lines or something like that. I cannot be sure, of course, but I would bet this is the case for many that consider they have a "big" dust problem. - Kalle
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | kmb wrote: The mirror throws the dust at the sensor. A very good point that I believe a lot of users dont realize.
rstuntz Senior Member 461 posts Joined Jun 2005 Location: Iowa, USA More info | Even if you haven't chagned the lens for a while, if have a lot of dust in the camera (say from a previous trip somewhere), then you will have dust on your sensor quite a bit. I took my 20D to the beach a while back and I must have gotten some dirt in the poor guy because the sensor would get dust and dirt on it all the time for a couple of months. After some time and a few cleanings, things settled down back to normal. -Ryan
May 26, 2006 17:09 | #9 Thank you for all of your comments! i will be ordering the rocket blower - Joanna
am_pitbull_terrier Goldmember 1,383 posts Joined Feb 2005 Location: Pittsburgh, P.A. More info | May 26, 2006 17:13 | #10 I don't know how everyone has all these dust problems.... I'm by NO means careful about using my camera or changing lenses and I have only had to clean my sensor (actually it was one little spot and I just did it to do it) one time in about a year and a half. I must live/shoot in a dust free enviroment Powershot G3
calicokat Cream of the Crop 14,720 posts Likes: 2 Joined Oct 2005 Location: Southern California More info | islandphoto wrote: Thank you for all of your comments! i will be ordering the rocket blower if that doesn't work I'll get the brush. But isn't it better not to touch anything to the sensor?I'd try the rocket blower, touching the sensor with anything should be a last resort, rocket blower usually does the trick "You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife
HectorsGTI Senior Member 399 posts Joined May 2005 Location: Grand Rapids, MI More info | May 26, 2006 19:26 | #12 There is a glass cover over the top of the sensor. So technically you wouldn't be touching the sensor. Hector
calicokat Cream of the Crop 14,720 posts Likes: 2 Joined Oct 2005 Location: Southern California More info | HectorsGTI wrote: There is a glass cover over the top of the sensor. So technically you wouldn't be touching the sensor. I am still more confident with the rocket blower, its all about confidence "You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife
May 26, 2006 21:20 | #14 Is this the reccommended brand? Does it matter if it's small/med/large? - Joanna
calicokat Cream of the Crop 14,720 posts Likes: 2 Joined Oct 2005 Location: Southern California More info | islandphoto wrote: Is this the reccommended brand? Does it matter if it's small/med/large? Giottos Rocket Air Blower - (Large) 7.5" Rocket Air Blower - (Medium) 6.6" Rocket Air Blower - (Medium) 6.6" Thanks Thats it, the medium is perfect "You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife
| Latest registered member is Thunderstream 1204 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
