Thread started 27 May 2006 (Saturday) 06:26
Last Nights Event, my first
burners
Joined Feb 2006
May 27, 2006 06:26 |  #1
Last night I had my first gig and I thought I share my experience.
It was a freebie for my aunt & uncle in-laws 50th wedding anniversary party. It was at night an open plan venue with a well lit inside and OK lit outside.
All my experience to-date comes from practice and knowledge gained from this excellent forum.
As you can see from my equipment list I am quite limited in range. Initially, I had my zoom mounted and hoped there would be enough light to avoid using flash as I am not yet too confident in using it well. I bumped the ISO to 800 and left it there, white balance was on auto as I was moving in and outside pretty much all the time and didn’t trust myself to reset it each time.
I thought I would stay on Av mode and everything would be hunky dory. No cigar. Even with ISO 800 and the aperture wide open I couldn’t maintain a shutter speed fast enough to avoid blur, so I switched to Tv mode and kept the shutter speed at 160 so whatever I zoomed to I would avoid blur, the aperture reading kept flashing all night and I switched on the flash and hoped for the best.
Yep, I could have started using my 50mm and I did try but it was too awkward to get good composition, in the well lit room there wasn’t a lot of space so I gave up on that. Only at the end when everyone was clapping, cheering etc did I move to the 50mm prime and got good exposure readings so I could avoid using the flash, in this last 20 minutes I got what I consider to be the best photos.
I’ve read before people talking about lens motor speeds, now I can see why they are important. Many times I missed an opportunity as the focusing had to catch up; it’s very annoying when that happens. Also, I now can appreciate the need for fast lenses if you want to take this game seriously. I already have a Sigma 12-24, 24-70 and 70-200 on the way, the latter two having apertures steady at 2.8. Unfortunately not in time for last night.
I was there about 4 hours and took 700 pictures. Never thought it would be that many. Needles to say I will junk probably 80% and keep the best ones.
Anyway, I take my hat off to everyone who does this professionally and admire their skill and stamina. I was knackered!
Canon 350D \ Rebel XT
Sigma 70-200 f2.8 EX DG Macro
Sigma 28-70 f2.8 EX DG Macro
Sigma 12-24mm F4-5.6 EX DG
Canon 50mm 1.8 + hood
Canon 28-105mm 3.5-4.5 II USM + hood
420EX Speedlight
SanDisk 2GB Extreme III & 2GB Ulta
Tripod \ Monopod
EOS_JD
May 27, 2006 06:37 |  #2
Hi Burners
It's not easy. I had a similar situation when I first started. Then I realised the importance of fast glass and a good flash.
Experience cannot be gained from these forums, only knowledge. Experience is gained by getting out and taking images and trying to put some of that knowledge to use. It's hard remembering everything when the pressure is on but it'll start to come.
Hope you got some good ones.
Regards
Jim
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
968 views & 0 likes for this thread, 2 members have posted to it.
1628 guests, 141 members online
