Thread started 28 May 2006 (Sunday) 08:21
URGENT HELP REQUIRED!
tantalus1662
May 28, 2006 08:21 |  #1
For no apparent reason, my in camera exposure dial display has stopped working in TV and AV Priority Mode. It still works in full manual mode. Can't think for the life of my what has caused this. I was using a very old flash on my camera last night but it is still a Speedlite so can't think that this is the problem.
Can anybody help PLEASE?
Please do Edit just tell me what you do!
Canon Digital Rebel (300D)
Canon EF-S 18-55mm f3.5-5.6
Canon EF70-300mm
f4-5.6 IS USM
Canon 50mm 1.8 II
Speedlite 580EX
Portable Storage : 40GB XSDrive
Editing : Photoshop CS2 (v.9)
AND A VERY BIG WISH LIST! :rolleyes:
My Gallery (external link)
jimlp
Joined Sep 2004
May 28, 2006 09:11 |  #2
Do you mean the actual display has disappeared or the control wheel on the back just has no effect? Did you remove all batteries, that would do a complete reset?
Canon 1DsMk2, EOS RP, Canon 17-40 f4L, 24-105 f4.0L ll, Canon 70-300 f5.6L IS , Sigma 85mm f1.4
tantalus1662
May 28, 2006 09:15 as a reply to  @ jimlp's post |  #3
When in TV or AV priority mode, I press the shutter release halfway, the exposure display does not move, I turn the rotation wheel to adjust settings and it still doesn't move. Am i having a complete mind blank, it did used to move I'm sure????? I've been using full manual mode for ages to try and increase my learning curve. The display is still there, it just doesn't move when adjusting settings.
Canon EF70-300mm
f4-5.6 IS USM
Canon 50mm 1.8 II
Speedlite 580EX
steved110
May 28, 2006 10:03 as a reply to  @ tantalus1662's post |  #4
Take out the batteries and do a complete re-boot type thing. Put on a different lens, preferably a Canon one, don't use the external flash. Go thru the menu to find the 'restore to factory settings' option - I'm assuming your camera has one but I've never used a 300.
Use the green square setting, take a few pics of something and see what they are like. then move to the P setting and do the same. Then got to Av, set a range of apertures and see what the camera comes up with in terms of shutter speeds, and how the pictures turn out. Then try the Tv setting, set a range of shutter speeds and see what the camera does for aperture, and how the pictures work out.
then do the same for manual. check your LCD screen through all of this to see how the display changes. If after all this you are not happy, there are 2 options, either the display is malfunctioning but the camera is working otherwise OK, or the camera is not working. either way, repair time.
Good luck!
PS also check your ISO settings, if the camerq cannot give the correct exposure it may give nothing at all. just a thought!
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
tantalus1662
May 28, 2006 10:28 as a reply to  @ steved110's post |  #5
Thanks for the advice guys but I feel like a complete idiot now. To dial in exposure compensation while in priority modes, I need to press the Av +/- button which I wasn't doing:oops::oops::oops: I think I'll stick with full manual mode - was learning more that way!
I'm sure my camera appreciated the reboot though!
Thanks again
Yours embarassingly.......
Canon EF70-300mm
f4-5.6 IS USM
Canon 50mm 1.8 II
Speedlite 580EX
steved110
May 28, 2006 10:48 as a reply to  @ tantalus1662's post |  #6
No worries, good news that nothing was actually wrong. Often it's the simple answer that fixes things. I know that sick feeling of worrying that I have broken something all too well ;)
Canon 6D
Jim_T
Joined Nov 2003
May 28, 2006 12:41 |  #7
Glad you got things going :)
FWIW, It's not a good idea to try 'an old flash you have lying around' without knowing the voltages that it has on the pins. Some flashes can have over 400 Volts.. This can damage an EOS DSLR which doesn't want to see much over 5 volts.
Below is a page you can go to in order to check out a flash before using it:
http://www.botzilla.co​m/photo/strobeVolts.ht​ml (external link)
You can adapt a high voltage flash to work on a low voltage system, using something like the Wein safe sync (external link), but old flashes whether they are high or low voltage, don't have the E-TTL capability that Canon DSLR cameras require. Non E-TTL flashes will always flash at full power, leaving you to manually meter.
tantalus1662
May 28, 2006 15:06 as a reply to  @ Jim_T's post |  #8
Thanks for that Jim T - you had me running scared for a little while. I checked out the link you gave and I was using a 200E Speedlite which is EOS safe - phew! A lesson learned for the future though!
Thanks again
Canon EF70-300mm
f4-5.6 IS USM
Canon 50mm 1.8 II
Speedlite 580EX
1,000 views & 0 likes for this thread, 4 members have posted to it.
1206 guests, 119 members online
