Thread started 30 May 2006 (Tuesday) 01:30
Sensor cleaning - must it be done immediately?
PAFC2004
May 30, 2006 01:30 |  #1
My 350D has a few bits of dust etc on the sensor, which do not seem to be affecting photos. Is it a problem if I don't get it cleaned for a while? It's damn expensive, and 'DYI' kits arent easy to get here.
Canon 5D MKii |Canon 350D | EF 17-40L | EF 70-200 2.8L | 580EX II | 430EX | EF 1.4x T/C II | EF 50 1.8II | Q6600 + 8800 Ultra
calicokat
May 30, 2006 03:00 |  #2
Get a rocket blower and blow the dust off, if that does not work, you can either swab it yourself or send it in for cleaning
"You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife :eek: :twisted:
My Website (external link)
Calicokat 1990-2007 RIP My Loving Kitty
peterdoomen
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
May 30, 2006 04:22 |  #3
The copperhill method works for me. I regularly clean the sensor, no need to send it in unless something gets stuck to it.
P.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock (external link) - Make your own Tabletop Studio (external link)- Glass Buying Guide (external link)
My ShutterStock Gallery (external link)
evandavies
Joined Feb 2006
May 30, 2006 05:50 as a reply to  @ peterdoomen's post |  #4
As the others said, the first thing is using a hand blower (not a can of air).
This will probably not get rid of everything tho.
Correct me if I'm wrong here guys, but I think that the longer you leave stuff on the sensor plate the harder it is to get off!?!?!?
From my experience when I cleaned the sensor the first time (soon after getting the camera) it was very easy to get it spotless but I just recently did another clean after about 3 months and it took 3 attempts (changing pecpad each time) to get it clean.
Does the sensor get warm when being used? Seems to me that maybe dirt gets baked on with time....?
Cheers,
E:¬D
- Gallery - (external link)
= Gear =
Lens focuses the light,
camera records the light,
you make it art.
Paul ­ R...
May 30, 2006 09:11 |  #5
I think as long as there is no finger print on the sensor, a hand blower would be able to get rid of all dust and makes sensor clean. When you do it, be very careful not to touch the sensor!
Green
May 30, 2006 09:11 |  #6
Sorry if this is off topic,
but is the 350D more vanurable to collecting dust on its sensor?
I see many people suffer from this problem in this particular model, including myself.
dsze
Joined May 2004
May 30, 2006 09:15 |  #7
All dslr's are succeptable to dust. Its just as common as having to wash bugs off the front of your vehicle in the summer ;) As others have said, Rocket-Blow (external link) your sensor several times holding the camera upside down above your head. If you still have dust in your photos, use the CopperHill Method (external link). The consensus here seems to be, "Don't pay Canon to clean it."
-daniel
"Life is not measured by the number of breaths we take, but by the moments that take our breath away."
-Gear List-
Longwatcher
obsolete as of this post
Joined Sep 2002
May 30, 2006 09:23 as a reply to  @ dsze's post |  #8
It is unlikely that "dust" will get baked on by the sensor. If the sensor gets that hot it is probably not a good sensor any more.
I had one spot on my 1DsMkII (in a usually not noticeable area) that would not go away using a blower or a brush, but then I had to clean it again recently due to some other spots that had cropped up and it went away with the rest.
I should also mention that my D60 has never had any noticeable dust to date. Don't use it much, but I loan it out and still no dust - can't figure why that one gets so lucky. For awhile the 1DsMkII was collecting dust spots left and right, but then lately doesn't seem to be picking up many.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
nation
Joined Jun 2005
May 30, 2006 09:37 |  #9
Like Longwatcher said the sensor won't generate enough heat to melt or fuse the dust to your sensor. So it's not a problem if you chose not clean it off immediately.
For whatever reason if the dust does stick and a rocket blower isn't enough you can use the Copperhill method to get rid of anything stubborn.
Judging by your avatar your in Oz. If yes you can try these guys for your sensor cleaning needs:
http://www.qualitycame​ra.com.au …cPath=33&produc​ts_id=1359 (external link)
7D and lenses.
Curtis ­ N
Master Flasher
May 30, 2006 10:55 |  #10
It won't be a problem until you need f/11 or f/16, at which time you'll wish you had cleaned it. ;)
PAFC2004
Jun 01, 2006 01:21 as a reply to  @ Curtis N's post |  #11
Thanks for the help guys.
nancypics
Jun 01, 2006 02:39 |  #12
I used an infant nasal aspirator to clean dust off mine. Just a couple of gentle puffs, and I made absolutely certain it (the aspirator) was dry and clean first (puffed it onto a mirror). Trust me, I'm paranoid ;-)a Anyway, it did the trick - I had a little (1 mm?) piece of hair on the sensor that blew right off.
EOS 5D
f2.8 100mm Macro
(still saving for some L series lenses...)
Film: Contax/Zeiss
www.nancylovering.com (external link)
1,764 views & 0 likes for this thread, 11 members have posted to it.
1024 guests, 112 members online
