Thread started 13 Jan 2002 (Sunday) 22:09
Loose lens mount???
Scottie
Joined Dec 2001
Jan 13, 2002 22:09 |  #1
I just received my D30 and could not be happier except for this little problem. When ever I hook up my 70-200 L series it clicks in normally and works fine, however if you grab the lens aroud the barrel the camera turns back and forth probably only 1/8th of an inch. this does not happen when the lens is on my other canon bodies. Has anyone ever had this same problem? If so how did canon deal with the problem and is it worth sending it back to canon.
Thanks for the advice.
Scott
mpeltier
Joined Dec 2001
Jan 13, 2002 22:15 |  #2
from what I understand this is normal on all lenses. You notice it more as the lens weighs a lot more than say your 50 f/1.8 . I have the 100-400L IS and it does this. I dont notice it on a 75-300 of the 50 f/1.8 but they weigh less
soumya63
Joined Dec 2001
Jan 23, 2002 02:29 |  #3
This does not appear normal to me. I have a 300mmL which though not as long as 100-400 fully extended, but quite long and heavy. Even when fitted with EF-25 extender, I can not see any backlash in the lens mount. Frankly speaking 1/8th inch backlash will definitely throw all you focus upside down when working with Macro or telephoto lens. It may not be a bad idea to send it for service.
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Jan 23, 2002 06:38 |  #4
Scott
I had this 'problem' too (only less than 1 mm slack) and after Canon changed the backside ring of my 70-200 they said it didn't help - it seems to be normal that you see slack because the lens weights so much. I don't know if that is the right conclusion, but at least if it's same with most 70-200's and it does not affect image in any way I'd say that it's easiest to ignore the problem (if the slack is small - if it's as big as you say then it sounds like too much to me and worth a check - maybe D30 lens collars can be slightly different).
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
Nobodyknows
Jan 05, 2010 17:52 |  #5
I have noticed this with my 28-300 f 3.5-5.6 L that is a very heavy lens. My concern is the lens and my 1D body are suppose to be dust resistant surly this problem could be a weakness?
EOS 1D Mk3 body, Canon EF 28-135mm f3.5-5.6 IS USM, Canon Speedlight 580EX II, Canon EF 28-300mm f/3.5-5.6L IS USM and Canon EF 17-40mm f/4L USM lens
crn3371
Jan 05, 2010 18:02 |  #6
This could possibly be the record for post resurrection.
Nobodyknows
Jan 05, 2010 18:28 as a reply to  @ crn3371's post |  #7
Guess so but looks like things haven't got any better in all that time. ;)
jack ­ lumber
Jan 05, 2010 18:35 |  #8
My 100-400 has play when mounted on 20D, I have read that this play is to allow for expansion.
There is a fine line between "hobby" and "obsession"
5D-20D-7D gripped- all canon-28MM 1.8 - 50MM 1.8 -17-40 L -100MM 2.8 macro -70-200MM L F4- 100-40MM L -1X4 teleconverter-Sigma 20-40MM 2.8:D 580 EX 11 flash- manfrotto tripods and monopods.
Rio ­ Sundoro
Jan 05, 2010 19:09 |  #9
Most of my lenses have very slight play on the 40D. But on 7D, they are all tight.
flickr (external link) | gear
PacAce
Joined Feb 2003
Jan 05, 2010 21:50 |  #10
Nobodyknows wrote in post #9331751 (external link)
If the lens is dust resistant, it'll have a rubber ring around the the mount. This rubber ring will seal the lens (at the mount) whether there's a little free play or not.
...Leo
Nobodyknows
Jan 06, 2010 01:16 as a reply to  @ PacAce's post |  #11
That's right it has a seal but from what I can see the seal is not flexing it is moving/sliding against the body and I have started to have a dust problem.
Perfect_10
Joined Aug 2004
Jan 07, 2010 16:33 |  #12
Nobodyknows wrote in post #9334289 (external link)
.. I have started to have a dust problem.
Could be coming off this old dusty thread you resurrected ;)
My Gear List  :p
RFDII
Feb 21, 2011 14:53 |  #13
I have very noticeable play on my 1D MK III when I mount my 70-200 2.8. LII that is just weeks old. Difficult to measure but suspect it is less than 1/32". Lens mounts and snaps into place ok. More noticeable with extender. 50mm is rock solid.
mansalim
Feb 21, 2011 14:59 |  #14
after 8 years, everything will come loose..
NinetyEight
"Banned for life"
Feb 21, 2011 15:25 |  #15
mansalim wrote in post #11886375 (external link)
After 40 years it starts to fall off... :shock:
Kev
12,257 views & 0 likes for this thread, 13 members have posted to it.
Loose lens mount???
1252 guests, 137 members online
