Thread started 01 Jun 2006 (Thursday) 08:36
High contrast shots
anamorph
Jun 01, 2006 08:36 |  #1
Here are a couple of unadjusted RAW conversions (excepting white balance).
They aren't shots I want to keep, but I'm curious about the effect in the second image (close up) - it doesn't look real! I was really just mucking about,
but I'd love to hear some comments on this phenomenon - my error maybe or something else?
350D, Sigma 55-200..DC lens, 1/1000sec @f5.6, all other cam settings default.
EOS 450D
EFS 18-55IS EFS 55-250IS EF 35 f/2 EF 50 f/1.8 EFS 60 f/2.8 Macro
farrukh
Jun 01, 2006 08:43 |  #2
What ISO?
Seems higher ISO noise, and then you sharpened it a bit in RAW which not only sharpneded the image but also created strange artifacts from noise and edges are looking distorted a bit.
5D Mark II + 40D | Lenses: Sigma 150-500mm BigmOS / Canon 24-105mm F4L IS / Canon 70-200 F4L IS / Canon 85mm 1.8 / Sigma Macro 70mm f/2.8 EX / Sigma 10-20mm EX / Canon 50mm f/1.8 II / Sigma 1.4x APO TC / Kenko 2x PRO300 DG. Lighting: Canon 580EX II + Metz 58 AF-1 + Sunpak 383...
PaulEY
Jun 01, 2006 08:46 |  #3
I have found adding any sharpness or detail extraction in the raw convertor brings out artifacts like those.
evandavies
Joined Feb 2006
Jun 01, 2006 09:31 as a reply to  @ PaulEY's post |  #4
Looks like jpeg artefacts.
Are these in the original RAW image?
What compression did you save the jpegs when you converted?
E:¬D
- Gallery - (external link)
= Gear =
Lens focuses the light,
camera records the light,
you make it art.
anamorph
Jun 01, 2006 10:33 |  #5
Shot at ISO200. Ive made absolutely no adjustment to the RAW file, and the appearance is virtually identical to the converted image.
Heres the same crop from the recorded JPEG off-camera.
Saved at 59//100 quality
EOS 450D
evandavies
Joined Feb 2006
Jun 01, 2006 10:40 as a reply to  @ anamorph's post |  #6
Sure looks like its trying to sharpen...
What are you using to convert the RAW?
Can you try converting the RAW with any other software?
E:¬D
= Gear =
you make it art.
anamorph
Jun 01, 2006 10:59 as a reply to  @ evandavies's post |  #7
I'm using RAWshooter essentials, while I evaluate it - and Ive just discovered the reason behind it - 'apply sharpening' was ticked in the convertion options!
I thought something wasn;t quite right - but I wouldn;t have sussed it if you hadn't prompted me - thanks!!
Jim
EOS 450D
farrukh
Jun 01, 2006 11:01 |  #8
try DPP, its best on keeping such artifacts down.
anamorph
Jun 01, 2006 11:29 as a reply to  @ farrukh's post |  #9
Thanks, I'll have a play about with it now!
Jim
EOS 450D
1,150 views & 0 likes for this thread, 4 members have posted to it.
High contrast shots
1863 guests, 108 members online
