Thread started 02 Jun 2006 (Friday) 10:00
G5 - Lense Distortion .
Action_Man
Jun 02, 2006 10:00 |  #1
There`s no real point in complaining about it because it isent going to get better but here is a shot i did today which shows how bad it is :) ...
Large Image here (external link)
Action_Man
Jun 02, 2006 10:11 |  #2
This image may be a better example :) ...
One solution would be to buy a fish-eye lense and put it on backwards ? ...
Andy_T
Joined Jan 2003
Jun 02, 2006 10:48 |  #3
Hi Action_Man,
part of the 'distortion' you see in your second image is the result of a well known photographic problem known as 'converging lines' or 'keystoning' that is to be expected if you use a wide angle lens and tilt it upwards at a close distance.
Other than your mentioned solution of putting on a fish-eye lens, you might try to
- use a longer focal length (do not fully zoom out) and more distance from your subject
- use a higher shooting position
- try to correct it in programs like Photoshop (external link), PanoTools (external link) or PTLens (external link).
http://www.microsoft.c​om …age/more/ImageR​escue.mspx (external link)
Hope that helps :wink:
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Action_Man
Jun 02, 2006 11:26 |  #4
Thanks for the tips Andy - now i`m aware of it i know what not to do in future, i usually take 99% macro`s anyway so its no big deal to me ...
Action_Man
Jun 02, 2006 11:27 |  #5
And i was joking about the fish-eye lense btw :D ...
Terrywoodenpic
Jun 02, 2006 13:26 |  #6
I have taken the liberty of putting your pick through PTLens and Sorting the converging verticles in photoshop.
I used settings in PTLens for full wide on a G5... There was very little lens distortion.
However There was a great deal of converging verticals, which I sorted in photoshop using Distort, as you had both pointed the camera up and twisted it a bit to get the building in.
These corrections are normal and not the fault of the lens , but are caused by point of view and camera angle. all Photographs since its invention have shown thes realities, and ever since then photographers have found ways to make visual corrections.
Terry_______________
Over 60 years in photography
wasted money cameras never on film.
Action_Man
Jun 02, 2006 14:03 |  #7
Thanks for the reply Terry, i will use the PTlens in future if needed.
Here is another example - look at the telegraph pole on the left and see how it and the builings bend inwards ...
Terrywoodenpic
Jun 03, 2006 03:03 as a reply to  @ Action_Man's post |  #8
thumbnail
Hosted photo: posted by Action_Man in
./showthread.php?p=157​7757&i=i193529939
forum: Canon G-series Digital Cameras
This is caused by the camera pointing up a little, not the lens.
would be very easily corrected in photoshop.
andrewaaa5
Joined Sep 2004
Jun 03, 2006 03:25 |  #9
Action man, in your shot of the manor house, i pressume you were standing quite close and with the camera on a wider angle. One method to reduce these distortions is to stand a lot further back, and 'zoom' in to capture the house. Working for a greater distance with zooming in helps with these distortions slightly.. Otherwise this lens is functioning as it should be, and in my opinion if a quite nice lens
andrew crighton
website -- > www.butterpeanut.com (external link)
flickr -- > flickr/photos/andrewaa​a5 (external link)
1,718 views & 0 likes for this thread, 4 members have posted to it.
2266 guests, 130 members online
