Thread started 03 Jun 2006 (Saturday) 07:43
70-200 f 2.8L & 20D
Jw333
Jun 03, 2006 07:43 |  #1
I’m disappointed with the fit of my L series lens to the body. When locked in place the lens is not a tight fit and I can turn it. Does anyone else have this problem?
1D MKIII, 20D, BG-E2 Battery Grip, 24-70 2.8L, 70-200 2.8L IS, 400 5.6L, EF 1.4X II, EF-S 18-55mm f/3.5-5.6, 580EX Speedlite
ACDCROCKS
321 123 33
Jun 03, 2006 12:15 |  #2
I never had that problem, but I was using the IS version.
canon weight ;)
shutterghost
Jun 03, 2006 15:02 |  #3
um, whats your relative definition of "turn"?...
yes when the lens is mounted there is tiny amounts of "wiggle room" and i mean maybe 5mm worth of wiggle room. This may seem like a lot but really i've never mounted a lens and had it have a death grip on its mount.
KEEP SHOOTING
-Ed
JaertX
Jun 03, 2006 15:08 |  #4
nope....mine seems pretty snug. I can see how the mount would wear out though.
Jason - I use Canon and stuff
photonoobie
Jun 03, 2006 15:16 as a reply to  @ shutterghost's post |  #5
I have a 20D and 70-200 2.8L. I can move it literally 1/100th of an inch, so its not like its anchored in concrete. It can move barely.
delinian
Jun 03, 2006 15:38 |  #6
Mine fits very snug, no "wiggle" ?
Dennis
Delinian.com (external link)
GyRob
Jun 03, 2006 16:06 |  #7
i have a few canon lenses L's and they all have a mm of movment ,nothing to worry about imho.
Rob.
"The LensMaster Gimbal"
Mediasoldier
Jun 03, 2006 16:20 |  #8
Both my lenses are snug fits, don't move at all.
Photography of Trevor Henry (external link)
Canon Digital Rebel XT (350D) w/ BG-E3 Grip
Canon EF-S 18-55mm | Canon 50mm f/1.8 MkII |
Sigma 105mm EX DG Macro | Sigma 70-300mm DG MACRO | Sigma 10-20mm EX DG
Billginthekeys
Billy the kid
Joined Nov 2005
Jun 03, 2006 16:56 |  #9
most large heavy L's. including my 70-200 2.8 and 400 have a little bit of wiggle. its not a problem
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
ACDCROCKS
321 123 33
Jun 03, 2006 20:21 |  #10
It's when they fall off is when you worry lol. But dont worry about, if it gets worse, I would send it in or check on it.
canon weight ;)
Thornfield
Joined Dec 2004
Jun 03, 2006 20:53 |  #11
Define wiggle....as in the rings seperate? or do you mean that once you have mounted it into place you can turn it back a little bit....if the former I would be worried if the latter I wouldn't worry...all my lenses do it and it doesn't affect the image...which should be our main concern
Relationships are like photography, it has to click. :)
kenny12
Jun 04, 2006 04:01 |  #12
check the little screws on the lens mount, make sure they are in properly they can come a bit loose after a while
prep
Jun 04, 2006 05:39 |  #13
There HAS to be a little bit of clearance when the lens is mounted, it is a fundamental factor of the EF mount design. Unlike the FD mount.
~pr
1,335 views & 0 likes for this thread
70-200 f 2.8L & 20D
Latest registered member is Steve_m
334 guests, 273 members online
