Thread started 03 Jun 2006 (Saturday) 14:54
filter for 100mm marco 2.8 lens
Brodog2525
Jun 03, 2006 14:54 |  #1
I just got my 100mm 2.8 macro and lens hood last week and now i need to get a filter.....mostly for protection cause i get nervous when there is not a filter to protect the lens.
i was thinking of getting a multi-coating skylight filter like this one (58mm) http://www.bhphotovide​o.com …ghType=category​Navigation (external link)
i will use this lens for both macro and portraits. I want to be able to leave this filter on the lens for 95% of the time. a skylight filter will work for both macro and portraits, right?
is there another skylight filter you think I should get or should i get another type of filter? suggestions?
thanks
Canon 30D | 17-85mm EF-S with IS | 430EX Flash
50mm f/1.8 II | 18-55mm lens kit
70-200mm f/4 L
brodiehenry.smugmug.co​m (external link)http://www.BrodieHenry​.com (external link)
Jon
Joined Jun 2004
Jun 03, 2006 20:28 |  #2
Skylight or UV. UV would be a tad better as it doesn't reach as far into the visible spectrum. But B+W is a good brand and MRC is the right choice.
Jon
Cocker Spaniels
Brodog2525
Jun 03, 2006 23:04 |  #3
what do UV filters do? block UV rays?
70-200mm f/4 L
Jon
Joined Jun 2004
Jun 04, 2006 10:46 |  #4
Yes. Skylight extends a little into the visible violet-blue range, which isn't all that helpful on close-up work like macro and portrait, but can help with haze for long tele or landscape shots.
Jon
Cocker Spaniels
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Jun 04, 2006 11:58 |  #5
I use Hoya Pro1 SHMC UVs but B+W is a well respected make.
Macrophotography by LordV
Brodog2525
Jun 04, 2006 12:26 |  #6
ok thanks im thinking of buying this one: http://www.bhphotovide​o.com …ghType=category​Navigation (external link)
any reason why or why not?
thanks everyone
70-200mm f/4 L
Jon
Joined Jun 2004
Jun 04, 2006 12:27 as a reply to  @ Brodog2525's post |  #7
thanks everyone
No - go for it.
Jon
Cocker Spaniels
DaveG
Joined Aug 2003
Jun 04, 2006 13:15 |  #8
thanks
I have a UV filter on every lens that I have EXCEPT my 100mm macro. I'm a firm believer in UV filters but there's a potential problem using one on a macro lens. Now my 100 is the older non-USM version which has a significant space between the front element and the filter position. The newer USM version may well have shallower space and what I'm about to say may not be on point for the 100mm USM.
In any case I don't want that much space between the front element and a filter. The effect is the same if you are driving a mini-van with a long, long sloping windshield that's a long (yeah, you got it, it's long, sigh ...) distance from the driver. If crud gets on that windshield then you are much more likely to notice it since the dirt is well forward of your eye and thus closer to being in focus. Crud on eyeglasses often goes unnoticed since your depth of field is meters away from your eyes.
The same thing can happen with a filter on a macro lens. Lets face it, no filter is clean, especially in the middle of a shoot and if that grebe is far enough from the lens then it'll show up in the shot. Depending on the distance the grebe could just be a lack of contrast, or it could look more solid. In any case I just go without a UV filter on that lens.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
2,092 views & 0 likes for this thread, 4 members have posted to it.
1519 guests, 131 members online
