Thread started 05 Jun 2006 (Monday) 04:19
350D + Rocket
The ­ Old ­ Canon ­ News
Jun 05, 2006 04:19 |  #1
Had two small blips of dust on my sensor and had the relevant marks coming up on bright sky shots.
Invested in a Rocket! Wow! Blasted them little speckles into space.
Must say it was a wise investment. One little thing I did, was to mount the camera on my tripod and faced it downwards, so hopefully the dust came out, rather than blow it in further.
Thanks for the tip last week, eat your heart out Canon!
Canon EOS 350D
Canon EF 18-55mm
Canon EF 70-210mm f/3.5-4.5
Canon EF 50mm f/1.8 I
Velbon CX640
Vivitar 2500 (But Saving) for a 420EX
And Getting back Into It!:rolleyes:
col4bin
Joined Feb 2006
Jun 05, 2006 04:29 |  #2
good work. I always hold the body upside down when there is no lens on and the cap is off....translated as when cleaning or changing lenses. In addition, I always use the rocket blower after a session where I have changed lenses. Dust is easier to get off if you get it right away. Once it sticks, you need to resort to the swabs.
Frank
http://www.fiorentinop​hotography.com (external link)
Jun 05, 2006 05:38 as a reply to  @ col4bin's post |  #3
Is it true that the sensor heats up on multiple shots and makes removing the dust particles harder to remove, as I have read conflicting views.
It was nice to complete the removal, even clearer blue skies now!
Canon EOS 350D
Canon EF 18-55mm
Velbon CX640
col4bin
Joined Feb 2006
Jun 05, 2006 05:59 as a reply to  @ The Old Canon News's post |  #4
Not really sure about that but my guess would be yes it heats up since we are dealing with circuitry. It might be minimal but just enough to make dust stick.
Frank
Jon
Joined Jun 2004
Jun 05, 2006 07:34 |  #5
It would depend on what the dust consisted of, but offhand, I'd sort of doubt that the sensor would be able to heat up enough (between buffer size limits and frame rates) enough to cause problems with dry particles. Moist particles (salts, for instance) may get warm enough to evaporate leaving a residue, but even organic matter (pollen, say) would need a prolonged exposure to a fairly high heat to adhere.
One thing to bear in mind is that IIRC particles are more susceptible to a charge under dry conditions (think static electricity), so unless you're dealing with hydrous salts, it'll be mostly pretty dry particles being actively attracted to the sensor, and they'd be less vulnerable to heat levels likely in the camera.
A second thing to remember is that what the particles end up on, in active use, isn't the sensor proper, rather it's a clear cover over the sensor. This will further reduce the heat any particles will be exposed to.
Jon
Cocker Spaniels
1,255 views & 0 likes for this thread, 3 members have posted to it.
350D + Rocket
1888 guests, 105 members online
