Thread started 07 Jun 2006 (Wednesday) 21:28
?'s for anyone that hacked the Canon Off-shoe cable
Atomic79
Jun 07, 2006 21:28 |  #1
I'm about to hack an off shoe cable based on another thread here using various methods of extending the length beyond the 2 ft supplied. For anyone that has done this I have a couple of questions.
1. How does this effect ettl exposures, if at all? Dose the ettl system base its exposure on the amount of light only or does it assume that the flash is at or within two feet of the camera and make exposure decisions based on that?
Am assuming I can set the zoom manually since having the strobe at a different location then the camera I may want it to have different coverage.
2. Does this effect how the IR master/slave functions? In other words if I have the extended off camera cable on a 580 will it function the same as if it was on the camera as far as triggering slaves 580s/430s? I understand I'll still have to change flash settings at the master.
I guess I could wait until I make the cable and see for myself.
No matter how slow the film, Spirit always stands still long enough for the photographer It has chosen. Minor White
subtle_spectre
Jun 07, 2006 21:33 |  #2
I did mine and use a 10 feet extension...no problems.
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
cosworth
I'm comfortable with my masculinity
Jun 07, 2006 21:36 |  #3
I found no difference with my cables.
But they didn't work at 40 feet. Cut it in half and it works at 20.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
Atomic79
Jun 07, 2006 23:39 |  #4
Thanks to all. Cosworth I was going for a 50ft cable maybe I'll have to rethink.
spitstickler
Jun 08, 2006 17:59 |  #5
I did mine last week and it works with a 6 ft cable, but not with a 25 ft.
- Kirk
Ars longa, vita brevis
Wilt
Jun 08, 2006 18:04 |  #6
Signals thru the cable are simply data transmission, like computer cable to the printer....a longer cable does not affect the data content (although a long long cable can cause signal loss to the point of no data transmitted!)
Wilt
Jun 08, 2006 18:06 |  #7
Signal attenation is directly related to the diameter of the wires. That is why thicker speaker wire is use to run speaker signals longer distances, and thinner wires can be used for shorter distances. 50 foot cable could be done, but you probably don't want a garden hose sized cable!
JMHPhotography
Jun 08, 2006 21:35 |  #8
I actually have mine where I have 2 seperate 10 foot sections and it's all modular with PS2 connectors. ETTL works just fine. All you are doing is extending the hotshoe even further that the original shoe cord.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
Atomic79
Jun 09, 2006 16:46 |  #9
Ok here's an update. Thanks to all. Done my hack. Unlike others posted I used good old DB9 connectors not as pretty as say MiniDIN but I can buy a 50ft straight DB9 wired through for 11 bucks, seems to work fine. At least as far as my simple tests just now showed. Hooked the cable in, turned it all on, changed zoom and focus watched them change on the 430ex, tripped shutter and flash went off with good exposure. Again thanks.
1,558 views & 0 likes for this thread, 6 members have posted to it.
1038 guests, 118 members online
