Thread started 10 Jun 2006 (Saturday) 23:53
question about the image stabilization lenses
susancbk
Jun 10, 2006 23:53 |  #1
This may be completely obvious but i'm asking more for just a confirmation -
When using a canon lens with image stabilization - and your camera is on any sort of automatic setting - the lens will communicate with the camera letting it know it it can knock it down a couple stops... correct?
ie - it will take into account that an image stabilization lens is being used and adjust accordingly?
TGrits10
Jun 11, 2006 00:08 |  #2
Nope. It'd be nice if the cameras were that smart, but as it stands now they behave the same whether the lens is IS or not...the difference is in the result.
JaertX
Jun 11, 2006 00:15 |  #3
just curious...why would you even want it to do that?
Jason - I use Canon and stuff
susancbk
Jun 11, 2006 00:19 |  #4
ahhh ok ok im getting it - it still uses the slower shutter speed - but it compensates for the movements you may make during that slower shutter speed - helping reduce blur.
i guess i was getting confused because a lot of descriptions describe being able to take shots two stops slower... but really you're taking them at the same speed just getting better results because of less shake....
and if you put it on manual - you can make it go two stops slower than normal, and get a better exposed picture than you usually would in low lights?
just trying to wrap my brain around all this. heh :)
susancbk
Jun 11, 2006 00:20 |  #5
well thats kind of exactly my question jaert - a lot of descriptions talk about being able to take photos at two stops slower - which confused me because, like you said, why would you want to?
websurfer
Jun 11, 2006 01:48 as a reply to  @ susancbk's post |  #6
Shooting at slower stop with good results with IS or without IS means that the subject must not move, and who knows if it does My experience is that subjects are moving 90% of the time..
ONLY for portraits and other not moving subjects and with long 300mm, 400mm,500mm and 600mm lenses I think IS is really useful IMO.
Canon 50D / EF-S 10-22 f3.5-4.5 / EF 17-40 f4 L / EF 35 f2 / EF 50 f1.4 / EF 85 f1.8 / EF 70-200 f2.8 L IS/ EF 400 f5.6 L
robert_a_woods
Jun 11, 2006 03:23 as a reply to  @ susancbk's post |  #7
Its not that you get a better exposed picture, the picture will be exposed just the same as if it was a non-IS lens (based on your shutter speed, aperture and ISO as normal).
What you get is the same exposure, but the stationary objects should have less camera shake visible if you are using a slow shutter speed. Moving objects will still suffer from blur though......
Rob Woods, Nottingham, UK
Canon EOS 400D, Tamron 28-75mm f/2.8 XR Di ASP Macro
18-55mm f/3.5-5.6 Kit Lens, 50mm f/1.8, Speedlite 430EX
Apple PowerBook G4 + Aperture Software
Mark ­ Kemp
Joined Jul 2003
Jun 11, 2006 04:09 |  #8
IS reduces camera shake when hand holding. If there is plenty of light you can set a very fast shutter speed, there is no time for your hand to move etc. and the picture is nice and crisp. Trouble is if its a bit dark, even with the maximum aperture, you can't always get a quick enough shutter speed and still be correctly exposed. In that case there is a good chance that tiny natural movements of your hand will move the camera enough to make a slight blurring of the image. So you can switch on IS and it will try to cancel your hand movements and so make the image nice and crisp again. The camera settings are the same, still correct exposure, but the risk of camera shke is reduced. It is usually stated that you can hand hold without significant camera shake at about 2 shutter speeds slower (2 stops less) than you can without IS.
GyRob
Jun 11, 2006 06:22 |  #9
an esample were IS really helps is to alow a slow shutter speed to produce prop blur in a plane or copter a 200mm lens on a 1.6 crop needs around 1/500sec to avoid shake that would stop pro blur but with IS you can drop down to around 1/200 get prop blur and no risk of camera shake.
Rob
"The LensMaster Gimbal"
thetolleyman
Jun 11, 2006 13:46 |  #10
I like to shoot wildlife either at dawn or dusk. Since there is less available light at those times and wildlife usually requires that I shoot at long focal lengths IS enables me to get photos that I would otherwise possible not get at all.
At 300mm, rule of thumb is that I need a shutter speed of at least 1/300 sec to avoid a blurred photo due to camera shake. Well, its not uncommon for me to only get proper exposure at speeds much less than that, say 1/90 or so. Most of the time the IS will allow that. Of course, as mentioned, that does nothing for moving subjects.
50D 430EX
35-105 (old school) Sigma 70-200 2.8
28-200 EF 630 Film Tamron 11-18
MagentaJoe
psycho clown
Location: Having breakfast at the circus, with the lions and the clowns.
Jun 11, 2006 17:11 |  #11
I just created a simple diagram to help those wondering about image stablization and their function. I hope this helps some people who are just figuring these things out.
IMAGE: http://ceretti.com/msn/potn/shake.jpg
Arguing with a psycho clown can be harmful to your funny bone.
5D-Grip, 40D, 35f2, 50f1.4, 85f1.8,100f2.8macro, 135f2.8sf, 17-40f4L, 24-70f2.8L, 100-400f4.5-5.6isL, 580ex, 420ex, 430ex, 430ez
https://photography-on-the.net/forum/showthre​ad.php?t=442750
GyRob
Jun 11, 2006 17:15 |  #12
thats really good MagentJoe .
Rob
JaertX
Jun 11, 2006 18:17 |  #13
Hey Joe...that chart reversed would be a pretty good explanation of how subject movement is less of a problem the further the subject from the lens...the exact opposite of shake.
MagentaJoe
psycho clown
Jun 11, 2006 18:44 |  #14
Thank you JaertX. I was thinking of that in the chart but I wanted to keep it simple to understand. I was hoping that someone would bring that up! :-)
Image Stabilization really only makes sense in longer focal lengths. For shorter it's better to have wider aperture.
zacker
Joined Jan 2005
Jun 11, 2006 19:24 |  #15
i use my IS because, esp at full zoom, im one shakey bastard!
-zacker-
http://www.theanimalha​ven.com (external link)
My Facebook, Friend me If you want!http://www.facebook.co​m/brokenfencephotograp​hy (external link)
http://www.facebook.co​m/theanimalhaven?ref=t​s (external link)
2,051 views & 0 likes for this thread, 14 members have posted to it.
2287 guests, 133 members online
