Well, I had the choice and I wen't with the non-APO version because I was tight for money. I am very happy, it is actually my first telephoto. It tends to get soft after 200mm, which can be a bit of a problem when in macro-mode (which can be activated between 190-300mm on mine, supposed to be 200-300mm).
I'm happy with it, I got what I expected for $175 CAD. Its a good lens IMO, but can't be compared to any of the L's (wouldn't expect it too :P).
It is really sharp when f/8 to f/11.
I'm not sure about the APO version, other than it has better glass.
Some examples (they are web shots, so not the best indicators, I'll post some 100% crops if I can get around to it):
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Hope that helps man, good luck with your purchase.
